Sylvania LC320SS8 32 in. LCD Television Logo
Posted on Jun 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The previous owner of my sylvaniz lc320ss8 changed the size of the picture (zoomed or magnified it). He lost his remote. He gave me the set. I bought a universal remote. How do I change the image size back to standard size?
  • Anonymous Mar 15, 2014
    changing picture size with a universal remote
Steve Burt
Level 2:
Sergeant:
Champion:
  • Expert 245 Answers
  • Posted on Jun 16, 2011
Steve Burt
Expert
Level 2:
Sergeant:
Champion:
Answers
245
Questions
0
Helped
50150
Points
669
You have to use the buttons on the side of the T.V. through the picture menu.. There is an aspect ratio/ picture size option usually that will allow you to change it. You'll just have to learn how to navigate the menu with the volume/menu/channel buttons.
Change picture size firetv
To change the picture size on Fire TV, follow these steps:
  1. Go to the Settings menu on your Fire TV.
  2. Select "Display & Sounds" or "Display & Sound" (depending on your Fire TV version).
  3. Scroll down to the "Display" section and select "Calibrate Display".
  4. Choose the option that matches the aspect ratio of your TV (e.g. 16:9 for most modern widescreen TVs).
  5. Follow the on-screen instructions to adjust the picture size and position until it fits your screen properly.
  6. Once you're satisfied with the changes, select "Save" to apply the new settings.
Alternatively, you can also adjust the picture size and zoom level directly from the video playback screen. While watching a video, press the "Options" button on your Fire TV remote and select "Picture Size" or "Zoom" to adjust the settings.
Note that the exact steps and menu options may vary depending on your Fire TV version and software version.
2answers
Sony 34" XBR TV Picture does not fit on Screen. How to change setting?
Have you tried going to menu then to video options, screen size should be in that menu, also have got a zoom funtion on the remote, if so try using that. Do you have the owners manual, if not I will try to find a copy in PDF file format, just let me know.
How to make my fonts smaller
Quick answer - not specifically to change font size, but to change whole screen size
The whole screen size can be magnified (zoom in) by simultaneously pressing CNTRL + ; the reverse operation (zoom out - what you want I think) is performed by CNTRL - (press cntl and + keys simultaneously)
Or change (increase) the resolution of the screen by right clicking a blank a blank area of the desktop and selecting 'screen resolution' in Windows 7 or in XP one the tabs similarly labeled, and increasing resolution if not at max already.
12.February.2015
3answers
Picture size reduced - how to change back to full size
Please locate Zoom/ Picture Format button or option in Menu to adjust picture size.
If Zoom or similar button found on remote, press it repeatedly to get full screen picture.
Model and brand of your TV is not posted so button/ function name could be change as manufacturer use different labels for same fucntion.
1helpful
3answers
My screen size is in the 2X mode. I cannot get the screen size back to normal. Of course I lost the owner's manual. I have tried all the buttons on the remote w/o success.
the bottom half of the remote slides down ... that will reveil lots of lesser used controls including zoom .. you can also get to zoom via the menu system .. but its easier to just slide open the bottom cover on the remote and push zoom ..
1helpful
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
9helpful
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
2answers
Panasonic TV 50 inch plasma
Dear RyanVa21;
Try changing the picture size with your set's remote, press the aspect ratio button. The remote must be the original Panasonic remote.
Please let me know if that did it.
Thanks!
Richard
2helpful
Sharp TV - 32LW92H - Zoomed in
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
