D-Link AirPlus G Wireless Range Extender DWL-G710 (dwlg710) Repeater Logo
Posted on Jun 16, 2011
I want to change setttings on my D-LINK DWL-G730AP pocket router, but my ISP here in Dubai will not allow input of numerical IP addresses into the browser because such appears "suspicious". Is there a workaround for this limitation? How else can I get to the page to make configuration changes or to add a WEP password? Thanks.
5 Related Answers
Anonymous
  • Posted on Jul 04, 2008
SOURCE: I can't get to http://192.168.0.30/
i had the same problem. You have to connect the repeater with the cable to the computer and then go into the Network and Sharing Center. Klick there on Manage Network Connetion and the go into the properties of you local are connection.Go into the proprties of your tcp ip.
Change from automatically to manuel ip adress.
And type under ip adress and default getaway 192.168.0.30 and Subnet 255.255.255.0.
Klick on ok and you should be able to open the website now.
Anonymous
  • Posted on Apr 05, 2009
In XP go to network connections, right click on local area connections, left click on properties, under "This connection uses the following items:" left click on internet protocol (TCP/IC) to highlight it. Left click on properties. Change the IP: address to 192.168.0.130.
Subnet mask: 255.255.255.0.
Default Gateway to:192.168.0.30.
Click OK.
Open your browser and type in the address box: 192.168.0.30 it worked for me.
Big-Daddy-Ray
Anonymous
  • 742 Answers
  • Posted on Oct 22, 2009
SOURCE: How to Change DWL-G710 IP address
in your case, you only need to change the range expander's IP address from 192.168.0.30 to 192.168.1.30
to do this, you need to connect a computer's LAN cable directly to the range expander's LAN port. when both devices are powered ON, then access the initial IP address http://192.168.0.30
when you are in the web interface, click the LAN button and enter the suggested ip under the IP text box: 192.168.1.30 see figure below.
when you already set the IP, click on APPLY. then you are good to go. You can then connect the router, then connect the range expander to one of the router's port, then computers.
jrock3144
  • 26 Answers
  • Posted on Nov 05, 2009
SOURCE: I have an Airplus Wireless Range Expander how do I find the IP?
just press and hold the reset button till the lights on the front blink to go back to the factory defults.
factory IP address is 192.168.0.30
type that in your browser address bar after you reset the G710
Testimonial: "Very helpful, thanks for the quick response. Sharing knowledge over the net is the best thing we can do for each other."
Anonymous
  • Posted on Nov 18, 2009
I did this with Windows 7 but the same solution applies to Vista and XP.
1. Connect the Range Extender (mine happens to be the DWL-G710) by cable to your computer. 2. Open the Network and Sharing Center. 3. Click on the connection, then on "Properties" 4. From the list select "Internet Protocol Version 4 (TCP/IPv4)" and click properties. 5. Select "Use the following IP address" 6. Use the following settings: IP Address: 192.168.0.130 Subnet mask: 255.255.255.0 Default gateway: 192.168.0.30 7. Click OK then Close. Give the computer a few seconds to re-establish the connection. 8. Go back to your browser and type 192.168.0.30 again. It will work. 9. Don't forget to go back once you're finished and change the setting back to "Obtain IP address automatically."
Also, it's a bad idea to use WEP encryption as any password you would use is easily crackable within a few minutes using the Aircrack suite of hacking tools in Linux. Even someone using Windows can use a live Linux distribution such as BackTrack which is bootable from a CD to hack in and get your password. Once they have it they're in and use your internet connection.
Use WPA-PSK encyption or better and choose a password that can't be found in any dictionary or on the web. It can't be hacked as of yet.
1helpful
I want to extend 2640t router's range by using 3200AP as wireless extender. Could establish handshaking between two devices using physical (cat6) cable but not wireless connectivity. In which mode 3200AP...
yes u can just use the same range ip address for both device like 192.168.0.1 for dlink and 192.168.0.2 dor airplus.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
2answers
I need to reset the Admin settings on my wireless router.
Press and hold the reset button on the back of the router for 15 seconds and it will load everything back to default.
2answers
Wan indicator does not light up..
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
Home > Wizard
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Home > WAN > Static IP Address
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
Starting
IP Address- The starting IP address for the DHCP server’s IP assignment
Ending
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
3answers
hi tasosantonio
have you tried ip address. 192.168.0.1
DWL-G730AP
riz.
1helpful
G730AP does not have correct IP
The address 169.254.xxx.xxx is a private network address. This means it is not connecting to anything.
Normally to do a proper hardware reset you will have to remove powere to the AP, press the reset button in (hold it there) then add power while still holding the reset button for 10 seconds after power is applied.
Do not put too much pressure on the reset button, it will break off inside.
After that, allow around 60 seconds and see if you can connect to it now. If not, then go into the properties page of your wireless card and set the IP info manually.
Set it to say:
192.168.0.2
255.255.255.0
192.168.0.30
Hope that helps. =)
38helpful
5answers
Every time I try to begin the configuration for my DWL-G730AP router, when I type the http://192.168.0.30/ in the URL, Gateway and Google tell me they can't find this address and instead give me a list of suggested web pages. My D-Link router instructions say to type the above in...
2answers
Problom
well....don't keep us in suspense...finish the rest of the story...c'mon....Don't do this to us!!!
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
