Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Today suddenly
my xps m1330 went down and only power LED was started flashing blue/orange. I presumed
that it was due to unknowingly power source was disconnected and now battery is
also drained.
I checked
the power source and restarted the PC. But still the orange LED was flashing. Checked
the battery status in BIOS and in windows as well: its shows 99% percent charged.
So to test the battery I just removed power sources but again PC went down :(
Now the
situation is that both BIOS & Windows says there is no battery in the
system. Where both at this location it was saying that battery was charged 99%.
So I just diagnosed system with In built utility and it returns error code 0146
2000-0146. Seems this error is reflection to disk issue.
Still pc is
running with AC power source but can not able sustain for a second on battery. I
am thinking this should be H/W issue but it would be great help if anybody has
solution or workaround for this issue.
Thank you,
The error code 0146 and the battery are two separate problems. First the battery problem is simple, it's bad and needs replaced. It being bad can refer to a developed short, a fail safe kicked in, or it's simply worn out. It is a battery after all, ad they don't last forever, the more you use them the quicker they wear out. A bad battery causing an issue is vary common with Dell machines, and a false battery reading with a failing battery is also common. The orange flashing battery light is the indicator that the battery isn't working properly, either by fail safe or wear.
The error code 0146 Is from the short test on the hard drive and indicates the a sector is going bad, and eventually the hard drive is going to fail. At this point, your hard drive may last days, or months. Either way, I suggest that you back up all important data, and purchase a new hard drive for the imminent failure. You might even go ahead and set it up, this way you'll be prepared when it does go, and you won't have any downtime.
hi,
i have Dell XPS M1330, i try to remove battery im not able to remove it, after trying this my battery not detecting whts the problem and still im not able to remove battery please suggest me any one knows this problem
hi,
