Cars & Trucks Logo
Anonymous Posted on Jun 13, 2011
My 2 amp fuse in the driver side fuse interior fuse box, that seems to control the wiper washer and wipers, keeps blowing...any idea?
Anonymous
Level 2:
Scholar:
  • Expert 134 Answers
  • Posted on Jun 13, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
134
Questions
0
Helped
42190
Points
354
I don't know for sure, but I believe it is supposed to be a 15 or 20amp fuse and not a 2amp. Check your owners manual or the fuse panel cover just to make sure
  • Anonymous Jun 13, 2011
    i appreciate that...but when i replaced that wee fuse, the wipers worked....i also understand there is supposed to be a wiper fuse under the hood.....so im getting a 'short' me thinks.....
1helpful
WHERE IS THE WIPER/WASHER FUSE LOCATED ON 2007 PONTIAC TORRENT
In the under hood fuse box , should have diagram inside the lid . Front wiper's or rear ? Front fuse # 36 - 25 amp. Plus Two relay's PCB hi and Wiper PCB relay . Wouldn't think this being fuse problem . Wiper switch , motor etc... The wiper's are control by a computer . BCM - body control module .
The windshield wiper/washer system consists of front and rear wipers. The front and rear wipers are operative when the vehicle is in accessory or run. The front wipers have 4 different modes: Mist, Intermittent, Low, and High. When the front wipers are in the intermittent mode, there are 5 delay modes to chose from, commanded by the windshield wiper washer switch through the body control module (BCM). The rear wipers has an only one mode.
If the fuse is bad , could have a short to ground or wiper motor pulling to much current (amps) . Fuse's don't just blow for no reason ! Could also have DTC'S - diagnostic trouble codes stored in the BCM .
DTC B3715
DTC B3873
DTC B3875
DTC B3922
DTC B3715 02: Front Wiper Relay Drive Circuit Short to Ground
The body control module (BCM) controls the wiper motor based on input from the windshield wiper washer switch. The BCM monitors the wiper washer switch through three separate signal circuits and a ground circuit. The windshield wiper switch high signal circuit is used to determine high speed wiper operation, the windshield wiper switch low signal is used to determine low speed, intermittent, and mist operation through the use of a resistor ladder, and windshield washer switch signal circuit is used to determine washer operation.
The BCM controls the windshield wiper motor through two output controls, controlling two different PCB relays which control the desired wiper speed, high or low.
DTC B3922 00: Front Wiper Function Select Circuit
The PCB relay's are non- servicable , replace fuse box . Soldered in Your best bet mit be to take it to a qualified repair shop .
Looking for the fuse for the wiper motor 2008 chevy impala
WPR fuse 25amp under hood fuse box .
Wiper/Washer System Components
The Wiper/Washer System consists of the following components:
• Windshield wiper/washer switch
• Body control module (BCM)
• Wiper PCB relay
• Wiper high PCB relay
• Windshield wiper motor
• Windshield washer fluid pump
• Windshield washer fluid level switch
• WPR fuse 25 A
• WSW fuse 10 A
This is more then likely not a fuse issue !!!!!!!
Low Speed Operation
When the wiper switch is in the low speed position, ground is applied through the switch internal resistor and the wiper switch low signal circuit to the body control module (BCM). In response to this signal, the BCM energizes the WIPER PCB relay by applying battery voltage through the wiper relay control circuit to the coil side of the relay. This allows battery positive voltage from the WPR fuse to flow through the switch input side of the WIPER PCB relay and out to the switch input side of the WIPER HIGH PCB relay. Since the wiper high relay is de-energized and its switch contacts are normally closed to the low speed control circuit of the windshield wiper motor, the motor will operate at low speed.
Wiper motor low speed operation and the wiper PCB relay can also be commanded ON/OFF by using a scan tool. Refer to Control Module References.
The PCB relays mentioned above are soldered right into the circuit board inside the fuse/relay block under the hood . There are alot of reasons for the wipers not to work ! The fuse could be blown but fuse's don't just blow for no good reason , short to ground , low resistance high current flow etc.... Intermittant !
Power and Grounds
With the ignition in the ON position, accessory voltage is supplied through the 25A WPR fuse to the WIPER PCB relay, the WIPER HIGH PCB relay and the WS WASH PCB relay that are all located in the underhood fuse block. Refer to Wiper/Washer Schematics.
G200 provides ground for the windshield wiper motor and the WIPER PCB relay. G100 provides ground for the windshield washer fluid pump and the windshield washer fluid level switch.
My rear wiper, defroster and licence plate lights stopped working on my 2007 suzuki swift but when I open the rear hatch the licence plate lights come on . Any ideas what's wrong?bad ground?
[PDF]Wiring Diagram.pdf - Ken Gilbert
ken-gilbert.com/wrx/mans/99.../Wiring%20Diagram.pdf
Each connector number shown in the wiring dia- ... Rear defogger cord (Ground). Fuel tank cord,. Roof cord, ... circuit. Then check the switch, relay, fuse, ground, etc. 4. .....Rear wiper motor. Rear wiper ... License plate light RH. Tail light LH.
#? license plate light - Circuit Wiring Diagrams
circuitswiring.com/tag/license-plate-light/
2008 Volkswagen Newbeetle Main Fuse Box Diagram 2008 Volkswagen Newbeetle ...Parts: rear window defogger, shift lock, battery positive voltage, interior light, A/C clutch, ... brake light, daytime driving light, wiper and washer system, vacan, fuel pump, central ... 1997 Suzuki Geo Tracker Left Dash Fuse Box Diagram.
#? license plate light - Circuit Wiring Diagrams - Page 3
circuitswiring.com/tag/license-plate-light/page/3/
Audi A4 Engine Fuse Box Diagram Audi A4 Engine Fuse Box Map Fuse Panel ... mirror control, wiper, washer, horn, brake light, cruise control, heated rear window, ... 2003Suzuki Aerio Dash Fuse Box Diagram 2003 Suzuki Aerio Dash Fuse Box ... rear defroster, fuel injection controller, radio, A/T controller, hazard light, ...
What fuse do i replace to make my windshield wipers work Chrysler 300
Highly doubt the fuse being the problem . If the fuse is blown ,that circuit has a problem , short to ground , wiper motor drawing to much amprage . Fuse's do not blow for no reason . Fuse # 18 -30 amp . under hood fuse box . There is also a relay , wiper on/off relay in same under hood fuse box . Also wiper hi/low relay ! There is also alot of electronics involved . integrated power module , front control module , plus C.A.N bus network . How to Diagnose Controller Area Network CAN . Could be wiper / washer switch , wiper motor , communication problem , module problems , Relay problem . Google chrysler intergrated power module . they have had a lot of problems with that thing .
Escort 55 1.8d van fuse 25 keeps blowing and cant start my van.circuit says wiper and washers and it wont let me install new fuse without blowing.i have work on monday !Help!
Unplug the wiper motor and replace the fuse. If it works the wiper motor is shorted out. It may also be the wiring rubbed thrue somewhere causing a short.
Wipers not working 2005 maxima checked both fuse boxes can't find wipers
LOOK FOR BLOWED 20 AMP FUSE INTERIOR FUSE BOX, LOOK FOR BAD WIPER RELAY UNDER HOOD IN THE ENGINE COMPARTMENT.
Yes my fuse for my wipers keeps blowing and my wipers turn on when i plug fuse in even know the wipers are turned off.
The power distribution box in the engine compartment # 6 , 30 amp mini - fuse , front wiper motor , front wiper relay , front washer pump , FEM ( also # 7 , 25 amp mini - fuse , rear wiper etc. ) The owners manual shows to disconnect your battery cables before servicing anything in the PD BOX
your relay could be shorted which makes the fuse keep blowing
2helpful
2answers
Need to know the fuse box diagram, what fuse pertains to the wipers... the wipers quit today and I do not have the manual. I opened the hood and see the fuses etc, but have no idea which one is for the...
fuse panel in car on driver side by left knee under dash
Visual Inspection Chart
Mechanical Electrical
  • Wiper linkage
  • Washer nozzles
  • Washer pump hoses
  • Central junction box (CJB) Fuse 211 (15A), Fuse 215 (30A)
  • Multifunction switch
  • Rear window wiper switch
  • Wiper run/park relay
  • Wiper high/low relay
  • Windshield washer pump
  • Rear window washer pump
  • Circuitry
  • Battery junction box (BJB)
  • CJB
  • Generic electronic module (GEM)
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
