connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet. Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port! good luck!!
Try resetting your router.Unplug the ac from it as well as the modem.Wait about 5 minutes or so and try it again a few times it should fix it.If not your router may need replacing.
You need to configure your router. For that Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.0.1 or http://192.168.1.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Click on WAN settings and set those settings as your internet service provider settings. Enable DHCP if you want to get ip from router. Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router. Then you can connect your wi fi network with that code. Let me know if you need further assistance. Thanks for using FixYa.
1.TRY siting in a place wth less people ... actually wth my USR9108 i get disconnected even if some one is standing infrront of the modem so stay in a open place wth less people. 2.RESET your modem 3 tymes and configure ur modem by the settings given from the Telecom company. 3.Check ur modem antennae ... bcoz its modem is very FRAGILE... it sometimes have an internal wire break ,,,, TRY installing ur BRothers antannae on ur modem nd den use it....
you are providing the username and password from your laptop.
So its disconnectiong when you shutdown your laptop
Try to use the username and pass from the Modem itself .
Hope you can find difference.
Thanks
