SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
SOURCE: i have a samsung J1043 7kg washing machine, apon
3E means the motor is running below or above the programming RPM's, this is a real problem. hold down the two left buttons while pressing the power button. this will present you with the testing system. Press the temp button and T1 will appear. press the start button on the machine will move through the phases in 3 second bursts. if your drum doesn;t move your motos shot. Good luck
SOURCE: water coming out of drawer & door
Hi Gary,It sounds to me that you have a blockage within the pressure systemas this is a classic sign. If you take the top off the machine you will see a round switch with a few wires going to it.This is the pressure switch. at the bottom of this switch is a thin pipe,normally black or clear. there is a small spring clip holding this pipe to the switch, If you remove this pipe and gently blow down it you will probably find it is blocked. You will then need to follow this pipe to the bottom of your machine. At the bottom of the machine where this pipe is fitted you will see there is a chamber and it is this chamber likly to be blocked.Some times you may clear this with a small piece of wire by removing the small pipe and poke wire through, but best way is to see how this chamber is removed and remove it for cleaning.Ensure machine is off at mains. this chamber fills with water and causes air pressure within the switch at the top of machine, which in turn tells programe when machine is full and also when empty. If this fails then machine will not turn off water supply as long as it is on. there fore when you reconnect parts ensure they are tight and clips back in place. Good luck and hope this works. Failing this working you may need to call an engineer to check switch and possible fault on board.
SOURCE: F 12 whirlpool 6 th sense washing machine.
hello,
simple ,The "F 12" error code is an indication of a water
temperature sensor error. There is a chance that there is a loose wire
connection on the water temperature
what you need to do to fix up your washer is to check on the wiring connection from the power supply to the water temperature indicator.
thank you and thanks for using fixya.
Testimonial: "thanks it worked"
SOURCE: wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The
filter is located behind the silver plate at the back of the machine at
the
bottom. Four screws hold it on. Drain
out all the water. The filter is inside
the big black rubber hose attached between the pump and the main drum.
Remove
the plastic clip holding it to the pump unit and then the metal cir clip
holding it to the main drum. Inside is a white molded cone and a big
white ball
which floats. You will find a lot of junk here, clean out thoroughly. To
refit
put white cone back inside just as you found it, at the bottom, fit ball
back
into the cone. Attach to the bottom to the drum and re-fasten the cir
clip.
Finally reconnect the gator to the pump unit and tighten the plastic
clip. Check out the pump too before reconnecting.
And rate me nice pl for the
free help!
