Most times it's video read issue such as a dirty lens on the laser.If you smoke in the house or use a fireplace there is a lot of airborn stuff to leave a slight haze on the lens making reading the disk impossible.Try a standard cd or dvd lens cleaner.The on that looks like a cd and uses alcohol on one of the cleaning brushes on the disk you've got a 50 50 chance.
Convergence is dead.Replaced the 2 convergence ICS,should solved this problems.Try website Tv repair World.com to buy a Whole convergence board to replaced.Samsung/Akai use the same convergence board.
I looked around for a power supply for you and turn up nothing. I see your problem. Nobody is selling. Best just to fix the board itself.
What I would do is get a Service Manual over the internet. Nodevice.com is selling the Service Manual.
Usually cost under $20. It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part number lists. And most cases the new part cost less than $15 by searching on the internet with the part number.
It's possible that it's just a bad capacitor or transformer on the power supply board. Cheaper than replacing the board. I hope I solve the problem for you.
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Start by researching by your exact Akai model # on our
Fixya website = start with All Products>Akai> your model >
troubleshooting............................................T.
nice site to visit
