I have used the -rw dvd and I had tried following the guide lines for finalising the disk.
I have connected the power cable and inserted the disk.
I have selected the menu but I am not able to view the "finalise" option on the Disk operations menu.
Please help...
Just try this make sure you put it in playback mode and make sure its plugged in your adaptor.. I guess they don't want to risk running out of battery during finalization (may stop the disk)
put it in playback mode then presto the option comes up so make sure you put it in playback mode by pressing down on the on/off button.In my conclusion to finalize the disk you need 2 things: First make sure you are in the play mode and second plug in your power supply
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Rewritable DVD discs allow you to record and erase lots of times (up to 1000). Similar to DVD-R disc and DVD+R disc, DVD-RW is approved by DVD Forum, while DVD+RW not
did you finalise the disk after you finished the burn? depending on which burning software you are using some ask if you want to finalise the disk after a burn others just finalise or you might need to select multisession before the burn starts
hope this helps
