Leviton Acenti AC201-1LW 20 Amp, 120VAC, Single Pole Non-Dimming Electromec Logo
Anonymous Posted on Apr 23, 2011
Installed Acenti by Leviton single pole switch and when in "off" position, there is a flickering of light on and off, its like a pulse... model AC201-1LW... the only thing i can think thats wrong was after i checked the amps i noticed that the acenti switch is 20A and my old switch is 15A, breaker is 15A as well... would this cause it to flicker on and off? do they make 15A models?
Anonymous
Level 3:
  • Master 43,501 Answers
  • Posted on Apr 23, 2011
Anonymous
Master
Level 3:
Answers
43501
Questions
0
Helped
10845528
Points
101584
No you are getting a backfeed from somewhere else...either the neutral is no connected properly or you have a bad ground...
It has nothing to do with the amp. rating of the switch..
heatman101
  • 3 more comments
  • Anonymous Apr 25, 2011
    Yes, you are right, so of the 4 switches i purchased, 2 work fine and 2 have the backfeed issue.. All switches do work as i installed them in other spots of my home... so how can i resolve this issue? i live in a condo if that helps... im going to purchase 2 more switches, should i buy wire and try to ground the switch to the box? Im a tinbasher, and hate electrical work :(
    Are all of the switches on the same circuit, or are they on different circuits??? That could be a clue....and yes grounding to the box may help...
  • Anonymous Apr 26, 2011
    different circuits, one is a continuous pulse, the other is a pulse for about 5 cycles and then stops... its frustrating...
    Seems as though there is something on those siruits that is causing the problems... Identify what else goes off when you kill those circuits...then unplug everything... then plug each in one by one till you find out what is causing the problems..
  • Joseph Marquardt
    Joseph Marquardt Jan 01, 2015
    Are you using cfl or led bulbs? If so make sure the dimmers are rated for the type of lamp (bulb) you are using
Joseph Marquardt
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Jan 01, 2015
Joseph Marquardt
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
4394
Points
57
Check to make sure you are using dimmers rated for the type of lamps (bulbs) you are using. Incandescent, cfl, led or fluorescent.
Wiring diagram, need help installing.
Single pole switch?
http://waterheatertimer.org/How-to-wire-switches.html
Add a comment and describe product and application.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I purchased the pr 180 photo electric switch from home depot.there are not any wiring instructions enclosed.I have two black wires and a ground in the wall. there is a green ( ground ) black,red, & a...
Leviton PR180 is a single-pole or 3-way motion activated light switch.
Resources:
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=452283§ion=10892&minisite=10026
The green connects to bare ground wire.
The yellow-red is not used EXCEPT to replace 3-way switch. Cap off yellow-red wire when wiring single-pole.
Your single pole switch has two black wires.
One black wire is Hot from breaker, and the other black wire goes to Load.
Turn power on, and test each black wire to bare copper wire. Tester lights up on Hot wire.
Hot wire connects to PR180 black wire.
Load wire connects to RR180 red wire
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on switch or any do-it-yourself project.
Fixya is always less expensive than a service call.
I installed Leviton 2591 switch (to replace a broken one). The switch is supposed to be "off" when untouched and "on" when held pressed down. My switch is behaving opposite. It is...
You have installed a "Normally Closed" (NC) pushbutton. You should replace it with a "Normally Open" (NO) pushbutton, sometimes called a "momentary" switch.
I have the unit wired and it does not wotk.I have black to black,red to red green to ground and white to white,any thoughts? Thank you
Electrician test wiring before connecting anything.
First of all, you don't mention what type of switch was replaced.
1) Leviton 6230 countdown timer is made to replace single-pole light switch only.
Single pole is where 1 switch controls the Load (light fan motor)
Your wiring sounds like 3-way switch.
3-way is where 2 switches control same Load.
For example a hallway usually has 3-way switches.
To confirm. If old switch has 1 dark screw, 2 brass screws, and 1 green screw, then that is 3-way switch. Use Leviton LTB15, LTB30, LTB60, LTB02, LTB12 countdown timer for 3-way.
Smarthome sells product and shows .pdf manual
http://www.smarthome.com/4255/Leviton-LTB60-1LZ-4-Button-10-20-30-60-Minute-Countdown-Timer-Switch/p.aspx
2) If old switch has 2 brass screws and 1 green screw then that is single-pole switch.
3) If you are replacing single-pole switch, here are testing & wiring instructions for Leviton timer.
Remove device and separate wires for testing.
Use ordinary two wire tester.
Tape tester leads to wood sticks so hands are away from power.
Do not untwist wires that were twisted together before you started.
Turn on power.
Test each wire to bare ground wire.
Tester lights up on Hot wire. This wire will connect to timer black wire.
Now you know Hot wire.
Test Hot wire to each of the other wires, excluding bare ground wire.
Tester lights up on neutral. Timer white wire connects to Neutral wire.
If box does not contain Neutral wire, then timer white wire connects to bare ground.
Timer green wire connects to bare ground wire.
Timer red wire connects to wire going to Load.
I have the power source in the ceiling. I want to run wire to a single pole switch to a ceiling light?
Disconnect 1 side of light. Wire nut 1 wire from switch to 1 side of wire from light. Wire nut other side from switch to light. You now have a switch inline.
Hooking up a combination switch with outlet and another switch
ok, i think what you mean is a 3-way switch- meaning two different switches that control one light and a single (pole) switch that only controls one light. you can't do that with the above switch. You need a combination 3-way and single pole switch.
Top Leviton Electrical Supplies Experts
john h
Sean Wright
Sean Wright
CJ Rock
CJ Rock
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
