20 Most Recent Leviton Decora Light Dimmer Switch Questions & Answers
Yes you short circuited the dimmer switch, it requires replacement to dim the light.
Leviton Decora... | Answered on Apr 06, 2017
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
Leviton Decora... | Answered on Feb 15, 2017
Check to make sure the hot conductor is feeding BOTH switches together, and
the switchlegs going to the individual loads
Leviton Decora... | Answered on Jan 01, 2015
Bad dimmer. Probably not using a high enough watt rated switch. Add up the total of all bulbs to be dimmed and get appropriately rated dimmer. 8x60 watt bulbs=480 watts. Make sure dimmer is rated high enough.
Leviton Decora... | Answered on Dec 31, 2014
you need a tester first fine out witch wire is hot then go from there
Leviton Decora... | Answered on Nov 06, 2013
ok shut off circuit breaker or fuse first.
then remove knob on dimmer.
next remove cover and screws.
then remove mounting screws.
loosen screws holding wires. if one is loose tighten and retry
dimmer and don't forget to shut power off after trying dimmer.
replace by reverse order. Make sure the wires are tightened
securely.
Leviton Decora... | Answered on Mar 25, 2013
Are these remote controlled dimmers? Do you have failing batteries in one of the remotes? Or perhaps a new remote control device has been introduced in or near your house that interferes with the dimmer remote signal. I had a similar problem that occurred when my boys played with their remote controlled cars.
Leviton Decora... | Answered on Feb 25, 2013
6633-pl is single-pole and 3-way dimmer made for max 600 watt incandescent or halogen load. This dimmer does not work for CFL or inductive loads such as motor.
I have no idea what a 'locator light' is?? Do you mean the LED indicator that shows when power is connected?
Troubleshoot section of manual does not show any solution for LED malfunction.
Contact Leviton for email tech support:
http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=37619&minisite=10251
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Leviton Decora... | Answered on Aug 08, 2012
Wiring is not best suspect.
If all the Leviton devices were installed same time, they may be failing at same time due to lifespan.
For example, ordinary on-off switch is a mechanical device with mechanical parts, and mechanical switches last many years longer than wiring devices that have electronic parts.
Electronic devices usually have standard 1 year limited warranty.
http://www.leviton.com/OA_HTML/ibeCZzpHome.jsp?minisite=10025&respid=22372
Leviton Decora... | Answered on Jun 30, 2011
Switch the hot wire and the wire going to the light around... you are wired basackwards...
heatman101
Leviton Decora... | Answered on Apr 29, 2011
Hello.
Had this problem my self a while back, here's what I found out. Firstly, it may simply be the switch is faulty. If this was a new install, take it back and try another. But before that, get all relevant information about the lights you are dimming. Here's why: Some light fixtures are incompatible with dimmers. They may dim - but not properly. Some lights/fixtures require specific dimmers to be used: incandescent or not, total wattage in fixture, and so on. Having this information may save you a trip if it's actually not the switch. Good luck.
Leviton Decora... | Answered on Mar 18, 2011
Hello.
Yes, this is a problem for some models. Continuous, uninterrupted operation can create a situation where the dimmer's "triac" (or in layman's terms - power regulator) continuously fires and a resistance will develop. This will overheat and damage the "transformer". There are dimmers with low voltage and load protection capabilities available. Your local "big box" store should be able to help you there.
Leviton  Decora Light Dimmer Switch Logo
69 questions posted
Top Leviton Electrical Supplies Experts
Steve
Gene Haynes
berniekruege
Level 1 Expert
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Leviton Electrical Supplies
Most Popular Question
leviton 1p160 dimmer
  • Electrical Supplies
