Question about Leviton 6230M Decora Four Preset Electronic Timer White
I have the unit wired and it does not wotk.I have black to black,red to red green to ground and white to white,any thoughts? Thank you
Posted by gatewayenter on
Anonymous
Electrician test wiring before connecting anything.
First of all, you don't mention what type of switch was replaced.
1) Leviton 6230 countdown timer is made to replace single-pole light switch only.
Single pole is where 1 switch controls the Load (light fan motor)
Your wiring sounds like 3-way switch.
3-way is where 2 switches control same Load.
For example a hallway usually has 3-way switches.
To confirm. If old switch has 1 dark screw, 2 brass screws, and 1 green screw, then that is 3-way switch. Use Leviton LTB15, LTB30, LTB60, LTB02, LTB12 countdown timer for 3-way.
Smarthome sells product and shows .pdf manual
http://www.smarthome.com/4255/Leviton-LTB60-1LZ-4-Button-10-20-30-60-Minute-Countdown-Timer-Switch/p.aspx
2) If old switch has 2 brass screws and 1 green screw then that is single-pole switch.
3) If you are replacing single-pole switch, here are testing & wiring instructions for Leviton timer.
Remove device and separate wires for testing.
Use ordinary two wire tester.
Tape tester leads to wood sticks so hands are away from power.
Do not untwist wires that were twisted together before you started.
Turn on power.
Test each wire to bare ground wire.
Tester lights up on Hot wire. This wire will connect to timer black wire.
Now you know Hot wire.
Test Hot wire to each of the other wires, excluding bare ground wire.
Tester lights up on neutral. Timer white wire connects to Neutral wire.
If box does not contain Neutral wire, then timer white wire connects to bare ground.
Timer green wire connects to bare ground wire.
Timer red wire connects to wire going to Load.
Posted on Dec 26, 2010
Helping a friend install a new unit... he has 3 wires where we took out the old unit (the old unit had 4 wires) .. the (source) 3 wire is black, white & bare.... the old and new unit have black, red,...
I suspect on teh wiring from the house the black&white will be the hot wires and the bare will be ground/neutral
use a volt meter before connecting tonew cooktop and check for;
black/bare to have 120volts
white/bare to have 120volts
if that is what you find...connect new cooktop as such;
black to black
red to (house) white
(cooktop) white and green to bare
GENE
Sep 07, 2011 | Whirlpool GJC3034 Electric Cooktop
On the top of the dryer there is block where the power cord attaches and there are 6 spaded treminals wit the following wires attached from left to right they are black wire, 2 blank, whiye double wire,...
the green wire is the ground wire,there should be a screw or connector for it near the block,it just connects to the frame so the unit is grounded,you should see on the cord a white,black,red and a green ground wire,on the block you should see the white wire connected,the black on another screw and the last one is for the red,if the white is in the middle the black should be on one side and the red on the other,they are color soated,if you say there are red small wires the large red should connect with them just like the black does,as long as you keep the white wires together,the black wires together and the red wires together you'll be fine and ground the green wire to the frame
Feb 22, 2011 | Dryers
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
Have a wiring harness for a CQ-C8100U panasonic CD Player/Head Unit, need a wiring diagram to hook it up to a 2002 Ford Explorer Sport 2 Door
Hello! Since I do not know if your vehicle is equipped with the Standard or Premium System I'll give both sets of wiring...You can identify which system you have by looking at the color of the ground wire...
Red=Standard and Black/Green =Premium
Standard...Constant +12=Green/Yellow...
Switched=Yellow/Black...Ground=Red...
Illumination=Blue/Red...
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium...Only power difference is Ground=Black/Green
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Feb 18, 2010 | Panasonic CQ-C8100U CD Player
I have a 1984 Honda X200R and it's not getting a
Hi and welcome to FixYa,
On Asian versions of an 84 Honda XR200R, the CDI unit has six wires:
  • blue/yellow - pulse generator
  • black - to ignition coil
  • black/white - engine stop switch;
  • green - ground;
  • green/white - pulse generator
  • black/red - exciter/charging coil at stator.
The ignition coil has 2 wires:
  • green - ground;
  • black - to CDI
Good luck and thank you for asking FixYa.
Nov 11, 2009 | 1985 Honda XR 250 R
I am attempting to replace an old bathroom exhaust fan with a Broan 680 fan/light. I am having a problem with the wiring. There are 2 wall switches for the light and fan. The existing wiring has red,...
The red and the black are the hot wires. One will be the fan and one is the light. The white is the 'common' for both fan and light.
It sounds like the new fixture has got one hot for both the light and fan, they will both run all the time from one switch. This is the blue wire. Hook it to the red or the black, which ever one comes from the switch you want to control it. Hook the white to the white on the new fixture.
The green is just a ground. hook it to the new fixture green or ground terminal. Cap or the black or the red that you don't use. It won't be need for the new one. The switch that it comes from will not control anything now.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 25, 2009 | Broan-NuTone FAN CONTROL SWITCH
LOOKING FOR WIRING DIAGRAM FOR STOCK HEADUNIT
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Yellow/Green
Left Front Speaker Wire (+): Green/Black
Left Front Speaker Wire (-): Light Green
Right Front Speaker Wire (+): Green/Yellow
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): Blue/White
Left Rear Speaker Wire (-): Blue/Black
Right Rear Speaker Wire (+): Pink
Right Rear Speaker Wire (-): Blue/Yellow
pls rate
Apr 04, 2009 | 2003 Honda Accord
Jenn air model JED8430bdb
A similar concern on a different model (8230):
To my knowledge, the:
green - ground
white - neutral
black - 120 to ground
red - 120 to ground but between red & black, it should be 240. A Jenn-Air JED8230 requires a 3-wire, 120/240 Volt, 60 Hz Outlet.
Pls consult/confirm with your local electrical utility/codes the availability/applicability of this power/wiring system or reference National Electrical Code, NFPA No. 70
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 12, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Nov 16, 2007 | Jenn-Air JED8430 Electric Cooktop
Leviton 6230M Decora Four Preset Electronic Timer White Logo
650 people viewed this question
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
john h
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
