I would try replacing the battery in your watch to see if it comes back to life. So-called "atomic watches" have tiny radio receivers in them that periodically listen for the official atomic time being broadcast via WWVB in Colorado. However, as you might imagine, it takes a lot more power to operate a radio receiver than it does to power a typical quartz wristwatch, and even with larger-capacity or double batteries, it's been my experience that these watches burn through batteries more quickly than traditional "set them yourself" watches.
An additional factor is that a watch that cannot find the WWVB signal will scan for long periods of time before putting its radio receiver into hibernate mode. So, if your watch has been stored in a basement, an interior room in a large building, or some other place where a radio signal can't penetrate, that would also shorten the watch's battery life.
1. Press mode button (bottom button left side) until the time and day appears. 2. With time and day showing press and hold set button (bottom right side). 3. City codes will flash. Press start/stop to select city that represents your time zone. 4. Press mode daylight saving time setting flashes. press start/stop to obey or disregard radio signal for atomic time. 5. Press mode hour flashes. Press start/stop to change hour (include AM/PM) Repeat the above step for the remaining values ( minute, seconds, month, day etc) Press set an any step when finished.
I have one of these, and look for the manual on the 'Net every time DST changes, and eventually figure it out. Here's how: (1) Hold down the ALM/SET button until you get past the alarm setting and you see 24H or 12H. (2) Step through the settings by pushing the ALM/SET button, changing each as desired by pressing the +/CYCLE button. Eventually you'll wind up with the time zone indication flashing (it's really tiny, and appears just below the time indication). Press the +/CYCLE until you get to the desired time zone. (3) After the screen quits flashing, press the -/DST button to get the desired setting. I hope this helps, and that I can find this post again next time change!
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
You could change between 12 and 24 hour by pressing the "Mode" button and the "Receive/Start/Stop" button at the same time. I still cannot figure out how to reset for Daylight Savings Time, though.
Offhand, I would say yes to the battery replacement. Though watches are not within my immediate field. This would be based on your post "2-5 minutes behind". As to the "lost signal" after a reset, may I request that you post back the specific model number pls.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
You don't need to set the watch back an hour. You just need to turn off the automatic DST adjustment.
Hold ADJUST for several seconds. Then, when DEN starts flashing (or whatever timezone you are set to), hit MODE The display will change to DST flashing at the top and on or auto flashing at the bottom.
Click TIME/MEMO or RECEIVE to change on->auto->off. Once off is flashing at the bottom, hit ADJUST twice and you will be out of DST mode and everything should be fine.
