The suds code is telling you that you're using to much detergent,you should be using H.E. detergent and like 1/4 cup full of it.if you use more than that it can oversuds and this is the number one cause of damaging the spider gear.if the spider gear goes you'll be in the market for a new washer,you'll know if it goes when in spin the machine will bang loudly,you can run the washer with just water,let it run for a bit and drain it to get the extra suds out,while it's agitating look in the machine most likely you'll see the detergent in the water.
