Our microwave is one year old and it sudenly stopped working. The light is on and the time clicks but the food does not get heated and the rotating glass top also does not rotate anymore. Can you tell me what could be wrong with this microwave.
Thanks!
Yes. This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a misaligned door hinge.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door
switch or mount trouble can be caused by slamming the door or by
opening the door while it's cooking without hitting the Stop pad first.
There
are plastic mounts inside the microwave which hold the door switches
and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes
it's a broken tab on the switch holder, allowing the switch to rotate
just out of position. This tab
can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or
handle as you try to start it. If it works or tries to work, then it's
a door switch mount or door alignment issue.
If
you or someone you know decide to look into it, we have critical
information on safety, disassembly and door switches at our site, and
our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also
be a "mini-manual" hidden inside the unit behind the control panel or
hidden on the left side behind the grille, which is very helpful when
troubleshooting & testing.
We ahve a frigadaire under the counter unit. It probably is 5years old. We did not install it. Unfortuantely I turned it on for 5 minutes to cook potatoes-forgot to put the potatoes in! Senoir moment.! It did not runa t all-no lights. Unplugged it-checked circuit breaker-checked outlet. A few minutes later-lights came on-clok works. It runs , but does not heat up HELP!
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
I am facing the same problem. Can i fix it by myself??
The light comes on, everything works, but the table doesn't turn and it does heat up. I'm so glad I came to this sight I read what the problem might be. ( The door not latching properly), and that is what it is. I turned on the microwave and held the handle while moving it a little up and down, and it WORKED !!!! Now how do I fix it????
Thank you !!!
Kelli
We've had this problem with our 2 year old microwave, too. Twice we've had it fixed by repairmen (we're not handy, especially with electricity). If it goes out when I first put something in it, I can jiggle the handle and it will start right up. But when it dies in the middle of cooking (like it did recently) the handle trick doesn't work. Adding another repair cost to what we've already put in to it, plus the very real possibility the problem will happen again, it will probably cost less to just replace it--even though I expect a microwave to last more than 2 years.
