Frigidaire PLMV169DC Microwave Oven Logo
Question about Frigidaire PLMV169DC Microwave Oven
My frigidaire microwave door is sagging and is about to fall off
I am having the same problem as the other poster. My microwave door is sagging and falling off. I don't see that a screw is missing but it appears to have a screw hole at the bottom near the left side bottom door hinge.
Posted by tonykanak on
Anonymous
    New Friend:
EASY get a machine screw, nut with washer. I believe I used a 1/8" machine screw.....(find something small to fit in the hole on the bottom hinge.
First step, take 3 screws off bottom to expose hinge area. Have someone hold it or support it so wires to the light do not pull out,.
Pop the machine screw through the front and then with your fingers get the washer an nut and tighten down.
If you want the professsional look. Paint the machine screw white first with a enamel white paint.
Posted on Jan 01, 2010
  • 1 more comment
  • Geraldine Dwyer
    Geraldine Dwyer Mar 14, 2014
    Hi Leuteraki, Thanks for your advice - it worked perfectly and now I've a door that works like new. I could not find a 1/8" screw at Home Depot, so went with a 1/4" one - and used 3 washers. And that size screw fit just find. It was a little tight getting the screwdriver at that angle, but it did work. Thanks for saving me a $100 service call.
  • Ronald Goldberg
    Ronald Goldberg Oct 16, 2014
    You saved me from buying a new microwave! The pop rivet repair was easy and worked great
  • Jimython Nov 25, 2016
    Wow - what a simple fix. Thanks for the help! Just did it and my microwave is like new!
warcraft demonhunter
    New Friend:
  • 7 Answers
Repairing the loose hinge is simple. First buy a pop rivet tool and 1/8'' or 3mm rivets.
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom. No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model
Posted on Apr 16, 2012
  • 2 more comments
  • rarubio401
    rarubio401 Mar 11, 2013
    Thank you very much, this was quite helpful. I'd like to add two more thoughts. First, use steel rivets because you want the metal of rivets and frame to match. Second, a rivet with a longer grip works better for me because the length compensates for the hole being more like 4 mm in diameter. Thanks again for a great solution.
  • Eleanor Broszeit
    Eleanor Broszeit Jul 09, 2014
    About a year ago this happened and we used this answer to fix our microwave. Now the bottom rivet broke off again and we got out the good old pop rivet tool and replaced the bottom rivet again. i agree that this is a manufacturing flaw and should be addressed by Frigidare/Electrolux.
  • Paula Pollock
    Paula Pollock Sep 29, 2015
    Fantastic and helpful answer. The fix worked great and we're being a little more gentle with the door now. We too agree this is a flaw that should be addressed. So grateful for the post. Thank you.
  • Andy Meier
    Andy Meier Nov 29, 2016
    Really helpful, I had the same problem and the pop rivet solution did the trick. Thank you!
Anonymous
    New Friend:
Agreed, this worked GREAT! Thanks again
Posted on Feb 17, 2013
  • warcraft demonhunter Mar 02, 2013
    Just to follow up after 11 months of slamming the microwave door, the pop rivits are still holding strong.
    I did upgrade the bottom 3mm rivet to the next bigger one by first drilling out the hole slightly. You can buy a cheap pop rivet tool with some rivets for about 10 bucks at Lowes.
Anonymous
    New Friend:
Mine is doing the exact same thing. The door is sagging. I think that the hinge connection on the inside of the microwave has come apart.
Posted on Oct 30, 2009
Chuck Schumacher
    New Friend:
I just repaired my Frigidaire Professional Series microwave using these answers. I found on another website that what looks like hinges - with the bottom one completely loose - is actually a single bracket, u-shaped, top to bottom. This bracket is what the pins in the door go into and hinge/pivot open and closed. The bracket was originally welded to the frame at the factory and breaks free, causing the door to sag. There are holes in both the frame and the bracket which initially looks like a screw fell out, but they in fact are not used. However, per the answers above, these holes can be used to hold the bracket.
I first removed the door: on mine, there is a plastic L-shaped piece near the top hinge (to left and below) which is meant to keep the door from going upward. This can be pried out using a screw driver. Then simply lift the door up and the pins come out of the bracket and you can remove the door.
Next, as per one answer above, remove three screws that hold the bottom plate on. They are evenly spaced across the front edge. This bottom then will rotate down. I used something to prop it and keep it from going too far down or falling off (there are wires to the light bulbs on it)
Instead of using a pop rivet, I used a machine screw, inserted in the bottom hole, front to back, with a washer and nut. Because the bottom is off, I was able to reach up from behind to hold the nut with some pliers. As an added measure, I found another slightly larger machine screw which fit snug into the upper hole/hinge, which I screwed in to firm it up (there is no way to reach back to secure a nut on it) - though I don't think it is necessary. The bottom screw holds the bracket, top and bottom, firm enough.
When the door was placed back on, I found that using these holes with screws moves the door just a fraction of an inch to the right - i.e. the door now closes just a tad harder, it is snug up to the keyboard. Not too bad though. I think it is a decent fix.
Posted on Nov 17, 2015
  • Chris Laughlin Jun 04, 2016
    Still a blessing after all this time, since the original post, for all owners of this unit! My repair was identical to Chuck's, and worked just the same....
  • Frederic Bien
    Frederic Bien Oct 29, 2016
    Chuck Schumacher, Thank You! Your detailed answer along with the other ones posted here have been a blessing and a joy. My repair was identical to yours. I lived for weeks with a broken door to my Frigidaire microwave, wondering if i should get a repairman or buy a new one... For less than $5 in screws, i was able to fix it.
    This bulletin board has re-established my faith in the great community of men and women. Thank you! ;-)
Anonymous
    New Friend:
The pop rivets work perfectly.
Ticks me off- I called the appliance co where I bought a kitchen full of appliances. They said they couldn't fix it. I was going to pay an $80 service call for 2 pop rivets!!!!
They said I just needed a new microwave. Unreal.
Thanks for the great advice.
Posted on Jan 21, 2013
  • TERRI GREEN
    TERRI GREEN Nov 17, 2013
    THIS IS OBVIOUSLY A MANUFACTURE PROBLEM THAT FRIGIDAIRE SHOULD SERIOUSLY TAKE CARE OF. I ALSO HAVE THIS SAME ISSUE
Ken Reeder
    New Friend:
Thanks for a terrifically helpful thread! I had never used a pop rivet tool before, so I had to make a trip to the hardware store to get a kit ($13). Then I did one of the two rivets wrong so I had to drill it out and try again. But, the end result is fantastic. If you already have the tool, and do the rivets right on the first try, you could be done in 10 minutes.
Posted on Apr 09, 2016
Sarah Seattle
    New Friend:
Thank you for the detailed explanations above! I fetched some small machine screws, washers and nuts. I unplugged the microwave. Covered the stove with a table cloth (so dropped screws wouldn't matter). Put a light but large object on top of the stove (empty bottle rack) to hold up the bottom cover. Unscrewed the three screws to let down the bottom cover. Popped off the little black plastic cover on the upper inside of the door near the hinge. That meant I could lift the door off the pins and place it carefully down. I waggled the loose hinge piece so that the top and bottom holes aligned. Did bottom hinge first, using the existing unused hole (clearly the designer knew it was a good idea and Fridgidaire cut production costs by a tiny margin by skipping it). Because the plate was lowered I could reach up and hold the nut with my pliers as I put the screw through. The top hinge hole I pulled forward with my fingers and tightened the screw into it without any back since it was unreachable. I reattached the three screws to hold up the bottom cover. And then got someone to hold a flashlight so as to see the tiny black pins. It took a couple/few tries to make sure they both actually are in the right holes and not just nearby. Then popped back on the tiny black plastic cover that prevents the pins from moving off. Shut the door. Plugged it back in and reset the clock. Turned it on! It worked!! Door is solid! Felt incredibly smug and joyous to have saved money and incredibly grateful to this site and all the folks above who shared your wisdom. You rock. :) Thanks! Sarah in Seattle
Posted on Nov 11, 2016
Frigidaire microwave door is sagging
Hello Irfan, thank you for your post!
From the information you have provided the door on your Frigidaire microwave is sagging. Your door could be sagging due to the hinges or the door being damaged. I would check to make sure there is no visible damage. It is possible that the hinges and door may need to be replaced as well. To help avoid any unnecessary part purchases you may need to seek assistance from a professional technician for proper repairs. -Matt
2answers
You will need new door and hinge replaced
send model # for price quote
My Frigidaire microwave door is sagging and about to fall off
I appreciate your post, Wayne!
From my understanding your Frigidaire microwave door is sagging and about to fall off. This could be an issue with your hinges or door. In order to check if you hinges are not damaged you may need to disassemble your microwave this is not a simple DIY job. I would highly recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid personal injury, future problems, or unnecessary part purchases. I hope this information is helpful for you. -Matt
2answers
Fix sagging frigidaire microwave door
Hello Rick, thank you for your inquiry!
From my understanding you need to fix a door that is sagging on your Frigidaire microwave. Your door could be sagging due to the hinges or the door being damaged. I would check to make sure there is no visible damage. It is possible that the hinges and door may need to be replaced as well. To help avoid any unnecessary part purchases you may need to seek assistance from a professional technician for proper repairs. -Matt
Door is sagging and causing it to not work properly
Hey friend, thank you for the post!
I understand that your Frigidaire microwave door is sagging and your appliance is not working properly. You could need to a new door or hinges. These intricate parts do require precision and patience, therefore when replacing the exchange of such components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Chris
1helpful
9helpful
2answers
Microwave door sags
I had the same problem. An easy fix is to remove the door by opening the door, take a screwdriver and pop the plastic retainer piece from just below top hinge on the door. Now lift the door gently and it will come off in your hands. Set aside and be careful not to let the loss bracket that passes into the microwave body fall back into the cabinet. I would suggest you use a small vice grip locked onto that bracket to keep from lossing it inside. You will see two holes, one near the top and bottom through the cabinet into the hinge. line these holes up with the hinge holes behind them and use a pop rivet gun and 3/16" rivets to lock into place. Then replace the door and retainer piece. If you only have 1/8" rivets you can hold the bracket lined up with the original holes and drill 1/8" holes of your own a little distance away from the original holes and then pop rivet through these holes.
6helpful
2answers
Frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
1helpful
Sagging microwave door
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If the door seal is damaged or out of alignment, there is a chance of leakage, which can cause burns, damage to the oven or even a fire hazard.
Sagging frigidaire microwave door
If your door is removable, look where there is a plastic seal or ring on the door itself. It is usually attached to a bracket or near there someplace. I have taken plastic washers and put in place, otherwise replaced the parts that are worn out on the door assembly.
Tell kids not to pull on door while in use. Harder said then done. I have 9 children and they all have done this. My youngest still thinks he can microwave GI Joe to death.
Anyrate, if the issue I gave doesn't work, try your local appliance repair store. Sometimes they can help by either repair or giving advice.
Good luck.
Top Frigidaire Microwave Ovens Experts
Marvin
Marvin
Jaime Hernandez
Steve
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
