erm,, when you say you cant hear voices clearly. do you mean that they seem to be a little lower in "obviousness" than they should be or are they way down ther as the background level is so much higher.
1. a little lower means you need to bring the trebble up and the bass down and bring up the centre and reduce the surround , this is basically tuning the sytem to your room.
you also need to check the dvd setting for audio out to ensure that the settings for the audio on the dvd are set to 5.1 ( if the little black spare connector is connected to your dvd player) or else set to stereo for "normal " palyback.
2. if the voice is way down compared to background sound track.
are you using an amp for the bass channel, this may need to be turned down. or the thing that looks like a spare connector on the end of the cable going to your cd5 unit is not correctly installed. can you tell me what the set up is.
An equaliser is, put simply, a more complex tone control, giving you the ability to cut or boost more specific frequencies than a tone knob, or bass & treble controls.
It comes in handy for tweaking the sound from your hi-fi to just the way you like it. But beware, as it can make your hi-fi produce sounds that are so bass or treble heavy, that you can damage your speakers if you're not careful.
Adding another compnent into the chain (like a graphic EQ) can add a little background noise but this Technics EQ is a pretty quiet one & you probably won't notice the noise apart from when there's no music playing & you've got the amp turned up high.
