Washing Mach... Master
- Posted on Apr 01, 2011
Re: Washer works but there is a leak and hose connections...
Look under the washer and see if the leak comes from a faulty drain valve/pump or from a loose hose clamp. If so remove clean - back-flush or tighten the hose clamp.
it is possible that the drain valve is clogged as you mentioned the hose to be dry and so the water seems to collect here and leak.
