Veho VFS-002M Film Scanner (35 mm) Logo
Have used my Veho scanner to upload quite a few slides and negatives but suddenly it doesn't work, the box on the screen where the picture usually shows is just blank.
4 Related Answers
Anonymous
  • 611 Answers
  • Posted on Mar 17, 2009
SOURCE: The 2400 Scanner quit scanning 35 mm slides as the top lid light
problem in the driver so pls check latested driver in the internet and download it then you problem will solved
Anonymous
  • Posted on Jul 18, 2009
SOURCE: scanner is reading my 35mm slides as negative rather than positive, there is no place to make a change as it is Full Auto mode?
Open the scanner software on your computer. Put it in Professional Mode. Go to film type and select Positive.e
Anonymous
  • Posted on Mar 29, 2010
SOURCE: My Mom purchased a Jobar's slide & negative scanner by RX Optics
install for scanner for umax astra 2500 for windows 7
Anonymous
  • Posted on Oct 10, 2011
SOURCE: I need to use the
install a program called Cheese. works great but without software dpi interpolation
My veho keeps telling me it can not find camera, I am using the scanner why>
Which version of Windows 10 do you have? The first few editions could use unsigned drivers from older versions of Windows. The last few versions of Windows 10 require signed 64-bit OS drivers which are not offered for most older hardware. Check your model and see which version of the drivers are available here: https://veho-world.com/downloads/ . (The downloads are compressed archives.)
An extra problem with these newer versions of Windows 10 is that they don't support TWAIN scanners any more. A WIA driver has to be available. There is a work-around software for some scanners at https://www.hamrick.com/ . The program is VueScan and it essentially translates TWAIN to WIA and back between the OS and the scanner. However, the list of supported scanners does not include Veho: https://www.hamrick.com/vuescan/supported-scanners.html . Also the program is limited to text documents with a watermark unless you pay for the software.
I wish I had better news for you.
(I have an older scanner (TWAIN) and have used the VueScan software successfully. The scanner belonged to a relative who replaced it after a USB cable issue. They'd been considering an upgrade anyway to begin digitizing family photos from slides.)
I need to use the Veho VFS-002m scanner on Linux. I can't find any way of installing it. Any ideas?
2helpful
Where do I download a manual of veho smartfix scanner
The user manual should be on the CD that comes with the scanner. If it is not there the company has a download page for support here: http://www.veho-uk.com/main/downloads.aspx
1helpful
Help! We opened the box for our new Brookstone Slide and Negative Scanner Model # SKU634402 and the installation CD was missing. Is there online installation available or should we just return the item...
A search for that model on Brookstone's website takes me to the iConvert Instant Slide and Negative Scanner. That scanner does not require an installation CD. It works by scanning slides or negatives and then saving them to an SD card. Many digital cameras use SD cards so you may have one already. Otherwise an SD card will need to be purchased separately.
Slides scan as negatives
this scanner usb cabal no didact tell me bored problam ya cabl problam 6600E
How to scan negatives & slides with the epson RX620
There are holders for the slides and negatives inside the top cover. Remove the white part and take out the holders. Place the slides or negatives in the holders and place on the glass plate. Then you choose the proper menu for copy or scan and follow the directions on the screen. I scanned quite a few slides and had no problem.
1helpful
3answers
My scanner doesn't scan negative
" I can only select platen as the sourc. the film setting has vanished" - I had the same problem. Unplugged the USB cable from a shared usb 2.0 hub and plugged into an old USB 1.1 dedicated port and it started working. No ideas why (perhaps in the hub it couldn't detect the scanner model correctly)
Top Veho Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Veho Office Equipment and Supply Expert? Answer questions, earn points and help others
