My Mom purchased a Jobar's slide & negative scanner by RX Optics
My Mom purchased a Jobar's slide & negative scanner and I can't get the software drivers to install. It is giving me a 0xffffec75 error code. I need help.
Posted by Maurice Dyer on
Anonymous
    New Friend:
Install for scanner for umax astra 2500 for windows 7
Posted on Mar 29, 2010
Need an driver update to Windows 7
Most VISTA software and drivers will work with Windows 7. If you get an error trying to load it, it may be because the installer looks for the OS identifier and it is not XP or VISTA. IF that happens, you can right click on the installer file/icon, and select "compatibilty mode" for VISTA to attempt to make it work. This is rarely necessary, however.
Aug 31, 2016 | Jobar RX Optics 35 MM Negative and Slide...
Is there a driver for Mac OSX (10.11.3)
The manufacture would be the primary source if a driver does exist.
Apr 04, 2016 | Jobar RX Optics 35 MM Negative and Slide...
About three weeks ago, or four I asked how to repair my RX optics. Where do I send it.
You would have to contact the manufacturer or seller that you bought it from in order to proceed with repairs.
Apr 16, 2014 | Rx Optics Slide And Negative Scanner
Does the HP photosmart 2710 scan negative ansd 35mm slides?
This multi function printer/scanner cannot scan 35mm slides and negatives.
Some flat bed scanners with a lighr scource that shines through 35 mm slides and negatives can scan them.
You will be better off getting a dedicated 35 mm slide/negative scanner.
Check out this WEB site foe slide scanners.
http://www.google.com.au/#q=35mm+slide+scanner&hl=en&prmd=imvns&source=univ&tbm=shop&tbo=u&sa=X&ei=dYFIUPKBKMSyiQedl4G4DQ&ved=0CEkQrQQ&bav=on.2,or.r_gc.r_pw.r_qf.&fp=4469b7ccc4340a33&biw=1016&bih=535
Sep 05, 2012 | Epson Office Equipment & Supplies
I need an all in one printer that also has a negative scan facility. Any suggestions, I have 2000 slides to scan .
Do you want a recomendation?do you want new or used? Typically all in one users don't scan slides or film, but flat prints, so they don't have the lighted back lid needed to scan film.I know that the Epson Stylus PHOTO RX-620 & 700 had a holder for 4 slides or 1 strip of film about 8 inches long
Sep 01, 2012 | Epson Office Equipment & Supplies
How to scan a slide on flatbed scanner
This model Canon MX700 cannot scan slides.
A flat bed scanner that can scan slides and negatives has a light scource that shines through the slide and negative fand is detected by the scanner sensor.
I suggest you purchase a slide scanner, it will be cheaper that getting a new flat bed scanner with slide capability.
May 17, 2012 | Canon PIXMA MX700 All-In-One InkJet...
Installed the JB5323 Jobar Slide & Negative Scanner into a Window's 7 Professional contained in my Dell and it will not give me all the different things it has. It won't convert the negative...
You don't need any special software or hardware to do this, and it's really easy too! Open one of the saved image files of the negative scan using Microsoft Paint. It's under Start -> Accessories.
Now click select in at the top, and then right click anywhere on the image. At the very bottom of the menu, there should be an 'invert colors' option. Click it. Your negative should now be a normal picture =).
Sep 10, 2011 | VuPoint FSC1VP
Help! We opened the box for our new Brookstone Slide and Negative Scanner Model # SKU634402 and the installation CD was missing. Is there online installation available or should we just return the item...
A search for that model on Brookstone's website takes me to the iConvert Instant Slide and Negative Scanner. That scanner does not require an installation CD. It works by scanning slides or negatives and then saving them to an SD card. Many digital cameras use SD cards so you may have one already. Otherwise an SD card will need to be purchased separately.
Feb 28, 2011 | Brookstone Cameras
I need software for iconvert software for a scanner I bought at brookstone. It did not come with a cd. Please help me
I had the same problem I found that the missing CD is downloadable on the Brookstone website.
http://brookstonemanuals.com/
Product number for Brookstone "Slide and Negative Scanner" is 598581 ... see back of your manual to confirm.
iConvert Film & Slide Scanner (598581) iConvert Film & Slide Scanner Drivers for Windows XP & Vista (119 MB)
Worked great for me!
Dec 31, 2010 | Office Equipment & Supplies
1,915 people viewed this question
Marvin
Marvin
