Not Associated ususally refers to a SSID or wireless network that has MAC
filtering enabled, and your NIC or adapter is not one of those that it
accepts or allow to "assocaite".
If you run "ipconfig /all" from the command line you should see that
your WiFI adapter has an IP address and gateway/DNS set to the router
IP.
Try disabling whatever encryption you have on your router, just to see if the network appears.
For Windows Vista and 7 64 bits : http://sabrent.com/drivers2/USB-AVCPT-64bit-Vista-Win7.zip
You seem to need another driver as well for the audio, here it is : http://sabrent.com/drivers2/USB-AVCPT-USB-EPM-286x.zip
You might also want to check their support website here : http://sabrent.com/support/.
Cheers!
1. press * and # to enter a secret support menu.
2. Enter code 123
3. Press Right button until "System Config Menu". Press OK.
4. Hardware Failure Status. Press OK
5. Press OK to Clear.
6. Cancel
7. Press Right button to Ink Initialization Status. Press OK
8. Cancel and Cancel to the secret support main menu.
9. Press Right button until "Print Tests Menu". Press OK.
10. Nozzle Test. Press OK
11. Wait until the print test is finish.
12. Press Cancel and Candel until the error 0×00000000 appear and then power off.
13. Power On again. The error disappear.
