Hello 1 Press MENU on the remote control. 3 Use Up, Down, Forward, Reverse buttons to select one of the picture settings, and press OK to enter the setting. 4 Adjust the picture quality. The following picture settings can be confi gured. Depending on the format of the picture source, some picture settings are not You must set [Home] in [ Location] Otherwise, the settings you adjusted will not be memorized after you You can set the location of your TV to [Home] or [Retail store]. Choosing [Home] gives you full fl exibility to change predefi ned settings for 1 Press MENU on the remote control and then use Up, Down, Forward, Reverse buttons to select [Setup] > [Installation] > [Preferences] > [Location]. 2 Select [Home] and then press OK to confi rm your choice.
Just enter to its picture and sound settings by menu option, and do the picture setting as you interested in.
2 Use Up, Down, Forward, Reverse buttons to select [ Setup] > [ Picture].
available
turn off the unit.
picture and sound.
3 Press MENU to exit.
