Have you managed to check that the drain pump is functioning correctly? Here is the final bit of my guidance notes on checking filters AND motors ;-0)
Disconnect power
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
