Yes, the backlight is a separate part. It can be removed from the LCD and replaced. The following video shows how to replace the backlight in a Sony camera.
Hello! Welcome to FixYa! According to the review features of Sony Cyber-shot DSC-T10 Digital Camera, this camera doesn't have a feature for superimposing date/time on images, however you can print images with the date superimposed, So by default u cannot put the time or date stamp on your images, but after taken the images you can manually put the stamp and can print the images. Don't hesitate to let me know if you want any further assistance. I hope this solution helps you Thank you and Keep using FixYa!
1. Turn OFF camera 2. Remove the battery or the power supply 3. Turn the switch to CAMERA for about 30 sec 4. Turn the switch to OFF 5. Install the battery or power supply 6. Turn the switch to MEMORY 7. Open the LCD cover and press the RESET button ( small inner button ) 8. You will be prompt to adjust date/time. Do it 9. Your problem should be solved
or If you have the manual of the DSC-T10 Camera please refer to the page number 64. Then, set the USB CONNECT option to PTP. Then, try transferring the videos. Please make sure that the Camera is not connected to the Computer while performing the steps. After performing the steps connect the Camera to the Computer which should resolve the issue.
this error message means that there is an melfunction in angular velocity sensor, peripheral cicuits.
Simply speaking steady shot function does not work well.
Please contact nearest Sony Dealer.
Best regards,
Arpi
