20 Most Recent Minolta Riva Zoom 70W Film Camera Questions & Answers
To whom ? Yourself or a prospective purchaser ?
Anyway, Fixya does not provide valuations of equipment, even when posted in the correct forum.
Minolta Cameras | Answered on Jul 29, 2019
Try gently cleaning the electronic contacts on the camera body and the rear of the lens, without touching the rear lens element or the mirror in the camera.
Minolta Cameras | Answered on Jun 10, 2019
Check your 'C' drive on PC. The path to the software will either be C:\Program Files\ or C:\Program Files (x86) if you have installed it.
If you need to find appropriate software, contact Konica Minolta, its usually a free download for you to install.
Minolta Cameras | Answered on May 19, 2019
  • Memory Card Form FactorSD Memory Card
  • Included Memory Card Capacity
    16 MB
  • Memory Card Slot
    SD card
  • Supported Memory Cards
    MultiMediaCard, SD Memory Card
Supported memory cards do not appear to be more than SD. To get above 2GB the supported memory card type should include SDHC.
Put on proper protection for your skin/eyes, then remove the old ones, clean with some general cleaner or cola(yes like Coca Cola or Pepsi, etc. as it eats corrosion), then replace the batteries with new ones and see what happens!
Minolta Cameras | Answered on Mar 24, 2019
DROPPING IS YOUR PROBLEM PERHAPS MINOLTA CAN ASSIST YOU BUT WE CAN NOT
Minolta Cameras | Answered on Jan 17, 2019
Most lens have a red spot on them. There is usually a red spot on camera (look on left side). The one on camera body is the unlock and needs to be pushed and held in as you rotate lens red spot towards the camera spot. When they line up you can remove lens. ?
Minolta Cameras | Answered on Oct 21, 2018
Contact Konica-Minolta
Minolta Cameras | Answered on Jan 24, 2018
The answer to this, and many other questions of a similar nature, may be contained in the manual. If you have no manual, you can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Minolta Cameras | Answered on Mar 02, 2017
An older camera, the DiMage A1 came with a 16mb card. Some cameras are picky about which cards work best. Compact Flash cards are sold in different speeds and your camera may work faster with a faster card. This camera can use Compact Flash type I or type II, and is compatible with the microdrive card. Since this camera was introduced the capacities of Compact Flash cards have increased dramatically so I believe you should be able to use a larger card with no problems but I would check out some of the online photography sites to read about other's experiences. Here is one good resource:
http://www.imaging-resource.com/
Hope this helps!
Minolta Cameras | Answered on Sep 13, 2016
Minolta Riva Zoom 70W Film Camera Logo
Popular Tags
1 questions posted
Top Minolta Cameras Experts
 Larry
Larry
ray gallant
ray gallant
Malcolm Fowler
Malcolm Fowler
Level 1 Expert
Are you a Minolta Camera Expert? Answer questions, earn points and help others
View Most Popular
Minolta Cameras
  • Minolta Cameras
Most Popular Question
old minolta camera quite few great
  • Cameras
