Hey. It's hard to provide a solution because of the limited detail that was provided, but be sure you've tried both of these things:
How to
connect your Wii to the Internet
Power on
your Wii console and press the A Button on the Wii Remote to reach the Wii main
menu. Use the Wii Remote to select the "Wii" button. Now,
select "Wii Settings" to access the "Wii System Settings"
menu. Using the arrow on the right side of the screen, scroll to page
two and select "Internet." Select
"Connection 1: None"(Don't see "None" in Connection 1?
Click the Connection 1 button, then chooses "Clear Settings.") Click on
"Wireless Connection" and then "Search for an Access Point Select
"OK" and the Wii will display all the wireless networks it finds. Select
the wireless network that is yours Select
"OK," "Save Settings," and then "Yes."The Wii
console will run a connection test with your wireless network when the test is
completed. You should see the following screen.Then you're almost done! After
your connection test, the Wii console will check if there is a new Wii System
Update available. Once you select "Yes" and "I Accept," the
Wii will begin to download any available updates...
Click here to download repair guide
