The manual says a code 10 is Electrical or mechanical. The say the solution is to turn the ignition on and off, or switch to a different source, then back to cd player.
Do you mean that a CD or DVD is stuck in the CD/DVD drive?
If it does not eject by pushing the eject buttom on the front of the CD/DVD drive, then straighten a paper clip and insert it into the tiny hole just below the drive tray and push the paper clip gently in the hole. The drive tray will pop out slightly, then grab the tray and pull it out until you can remove the CD or DVD disk.
Your refrigerator compartment temprature is below 32 degrees and freezing your water in the filter. Adjust the thermostat setting to a higher temprature setting using a thermometer in the referigerator as a refrence. 34-37 degrees is a good temprature range to keep food fresh.
disconnect your negative battery so it resets everything. But before you do that, does your radio have a security code? This won't let the radio play after disconnecting the battery. Its an antitheft deterrent. So I stress before doing that. make sure you have the security code
Check the CPU temprature from the BIOS. Sometimes if the CPU overheats the system will automatically reboot. High CPU tempratures goes form (60-70). You can also monitor the fan speed and cpu temprature using this utility http://www.almico.com/speedfan.php
Disc Eject Prohibit: This feature keeps the disc from ejecting even if the eject button is pushed. The disc eject prohibit feature is engaged/disengaged by pressing the CD and Eject buttons simultaneously for more than 2 seconds.
This is normally as sign that the writer is faulty, especially if ejecting on your pc's start up.
Just go through this first to check if it's just a driver fault.
Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete.
Restart the pc and windows will find the drive again automatically and install the drivers
