Posted on Mar 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The ink absober is full - Office Equipment & Supplies
RockTheHood
Level 2:
  • Expert 176 Answers
  • Posted on Mar 09, 2011
RockTheHood
Expert
Level 2:
Answers
176
Questions
0
Helped
433878
Points
302
Can you give me more details?
what printer is it?
you display an error?
Basically you need to unzip the printer and clean with warm water, waste tank, let it dry, then install the printer back.
need to know what you print out that I need to reset the error, waste tank full
How do i fix ip 4940 printer ink absober full problem
Open the printer carefuly remove the ink absober located under the head cleaning mechanism, wash it with water and liquid soap, dry it and re use againg. If you have new absober just replace.
My canon ip7240 is saying ink absober full how can i reset it ?
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
  1. Make sure the printer is turned off.
  2. Press and hold the Resume button (triangle inside a circle).
  3. Whilst it is held down, hold down the Power button. ...
  4. Keep the Power button held down. ...
  5. Release the Power button.
More items...
Reset Canon Printer ink absorber ' Fix-KB
www.fixkb.com/2011/06/reset-canon-printer-ink-absorber.html canon ip7240 is saying ink absober full how can reset it Google Search
see if this helps you out.
2helpful
3answers
Ink absorber almost full
Need to reset waste ink absober full.
Follow this step to reset waste ink absober full.
1> download iptool to reset waste ink absober full
Download here ----> Service tool 1
Service tool 2
After ypur download finish
> turn off your printer power switch
> open your printer cartridge door
> press and hold on/off button (never release)
> turn on printer power switch
> push your printer cartridge door switch with pen or anything can press door swith.
> then release on/off button
> close open door
> then press on/off button 1 more
now your printer is in normal mode( no orange led blinking)
Then you can use ip service tool to permanent reset waste ink absober full.
Hope this guide can help fix your problems
Extra download
Fixwasteinkabsoberflowip1000
There is a message that ink absorber is full and contact tne service centre.
Service tool 2
> close open door
Extra download
Fixwasteinkoverflowip1000
1helpful
My canon ip1980 appears error 5100 on my display i will replace my data strip but the problem still occurs. What should i do. Tnx
This problem is between waste ink absober full and ink cartridge.
Firstly your need to reset waste ink absober full.
Service tool 2
> push your printer cartridge door switch with pen or anything can press that door swith.
> close open door
IF after reset your waste ink absober full, problems still apppear error5100
> change your ink cartridge with the working cartridge
usually error e5100 due tow problems above
Extra download
3helpful
Absober waste ink is full. Pls help. error code
you need to replace the absorber waste ink pad and service the printer
The waste ink absober is full. If a service
You really need a service center for that, some have posted methods to reset here, but when the ink overflows it ruins the printer, and anything it leaks on.Canon customer service can tell you the nearest center. 1-800-828-4040.
Ink absober is full error 2 and 7 canon MP 160
it looks like you will need to take to a service center to get it replaced. You probably have used your machine a lot and the waste pads are full.
k24674
ADMIN Andrew
ADMIN Andrew
