Coby TF-TV4708 TV Logo
Posted on Mar 06, 2011
I have a coby tv but dishnetwork doesn't have a code for me to only use the dish remote to work it. Can you help me
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
82
Points
Try using code 626 or code 633.
3answers
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Code for setting up Dish network remote?
Hi my name is Mike Houston of DISH Network and I see you aretrying to find the code for your Coby TV. We currently do not have thatspecific code but we do have what we call a SAT Auto-Tune and it finds thethree digit code for your TV, I will send the link with the steps to help withthe setup; http://www.dishnetwork.com/SupportSection/sat-autotune
I have an akai 21' tv. I cannot program my dish network remote to work with the tv. None of their codes work. Do you have codes I might try
Hi my name is Mike Houston of DISH Network and I see youwant to program you're Akai TV to our DISH Network remote. There are some easysteps to allow setup to your TV and I will send the link, http://www.dishnetwork.com/SupportSection/remote-setup.Please select the receiver you have and it will take you to a help page. I willsend a link for a Power Scan and the power scan will find the remote code foryou; http://www.dishnetwork.com/SupportSection/power-scan-instructions.If you have any questions or concerns please e-mail me at [email protected].
3helpful
Codigos para tv plasma coby
Hola stlinfer350 mi nombre es Kimberly Escobar con DISH Network. Sera un placer ayudarle y proveerle este link que puede usar para encontrar el codigo a su televisor. http://www.dishnetwork.com/SupportSection/remote-setup aqui encontrara los codigos que pueden ser integrados al control y los pasos a seguir para programarlo. Si tiene preguntas adicionales por favor contacteme directamente a mi correo electronico [email protected]. Estamos aqui para ayudarle.
Kimberly Escobar
DISH Network
[email protected]
My remote will not turn the tv on or adjust the sound, it will change channels
First, try pressing TV on the remote, check if that solves the problem. Then press Sat and try the TV power button again. If the remote previously controlled the TV, you lost the code for the TV. If you have your Dish Network manual, check if you wrote down the code when it was originally programmed. Which specific remote/receiver do you have? The programming directions and code lists are available here: http://www.dishnetwork.com/supportsection/remote-setup . You can also scan all of the codes to find the correct one: see http://www.dishnetwork.com/SupportSection/power-scan-instructions . Additional remote/receiver manuals are here: http://www.dishnetwork.com/SupportSection/manuals .
The direct coding procedure for the Dish remote that I have is: while facing the TV to be controlled (after adjusting the key for TV1/TV2 in a multiple TV system), press and hold TV until all four indicators light up. Then enter the 3 digit code. Press and release the # key. Then see if the code TV powers off when you press Power. Then press Sat and check if the TV power button works. Try additional codes if the TV doesn't respond.
If you recently got a new TV and you tried to program the remote for your TV, your dish remote may not have the code you need. (Most universal remotes are limited to codes for devices released 6 months or more before the remote was programmed.) In that case, you should use the TV remote (and see if it has an option to control the satellite receiver). Alternatively, get a new universal remote that will control all of your devices. (The remotes that can be programmed by USB are the easiest to set up.)
I hope this helps.
Need dish network code for coby tfdvd1595
Hello, this has probably already been resolved, but if it hasn't, or you have any more questions, just follow the link below. The link will show you how to program the remote to your tv via power scan. I hope this information helps.
Becki Barned
DISH Network Customer Service
Need tv code to program dish network remote
Hey!!! Just follow the link below, and you will be good to go. The link will walk you through a power scan, where the remote will scan all codes on the tv until it reaches the right one for the remote. It sounds like a tedious process, but it is actually very simple and easy.
Becki Barned
I need the code for COBY t V set
willia_g
Here are the codes available for your Coby TV.
Coby Television 626, 633
I have also provided a link with the instructions on how to program the remote to your TV.
Instructions for programming remote, step 6:
Ray Calo
DISH Network
3helpful
Programming our dish network remote control. We do not have the remote code for our new Coby MODEL: TF-TV2214
1. Turn on your TV. 2.Press & hold the TV Mode button until all Mode buttons        light up. 3.Press red power button 4.Press the UP ARROW repeatedly (about 1 press per second) until your TV turns off. 5.Press # POUND The TV Mode button will flash three        times. 6. Press the POWER button to turn the TV on and try other buttons to make sure the code works. If you want to try another code, start over from step 1.
Below is the website for the online manual which will give further instructions.
http://dishnetwork.com/downloads/pdf/user_guides_and_manuals/remotes/6_3_RemoteManual.pdf
In looking at the manual no codes are given for the Coby brand TV. If the above process does not work, you'll have to call DishNetwork for further assistance. It may be that the remote will not work for your TV.
67helpful
9answers
Remote code for Coby TV/DVD
If you are a DirecTV or Cox subscriber, you may sync a universal remote to your television using code 1548 or 11548.
These codes are for use with the following Coby television models:
TFTV1022, TFTV1212, TFTV1513, TFTV1514, TFTV1524, TFTV1913, TFTV1923, TFTV2214, TFTV2224, TFTV2617, TFTV3217, TFTV3717, TFTV4717
If the codes do not work, or if you are not a DirecTV or Cox customer, the universal remote control manufacturer is responsible for creating and embedding a Coby-compatible code in the remote control. Please contact your cable carrier or the universal remote control manufacturer for assistance.
Top Coby Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Mikey
Mikey
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
