"wrong disc" message even when playing DVD which were watched on this machine before. I...
(More)
"wrong disc" message even when playing DVD which were watched on this machine before. I already used CD disc cleaner and kept machine on for 2 hours without disc inside the machine as per technical support from Coby.
When I put a dvd in the player, "wrong disc" comes up. I have tried many differnt dvds...
(More)
When I put a dvd in the player, "wrong disc" comes up. I have tried many differnt dvds which work on other players. I can hear it going around, It says "loading "for a while then" wrong disc." The screen comes up when it is turned on. The player is plugged in. The set up works also. All is on the default settings. Thank you
screen went dark, tv made a humming noise, then a burning smell came out of it. Now it doesn't work...
(More)
screen went dark, tv made a humming noise, then a burning smell came out of it. Now it doesn't work at all. Any advice? Is there a way to get the dvd that is in there right now out?
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
