20 Most Recent
Coby TFTV1923 19 in. LCD TV Questions & Answers
How do I change the input to HDMI
On newer tv's your remote has a button that says source. this is the equivalent of the old (input) button we're all used to. if you don't have the remote that came with your t.v you may have to buy one. or look for buttons on the side.
Coby remote rc-057
could be many things, make sure nothing is around the tv that would block the receiving eye for the remote on the tv. sometimes the receiver in the set can go bad.
Coby tv powers off
likely bad capacitors in the power supply. Google for part number Z1234TV
Code for setting up Dish
Hi my name is Mike Houston of DISH Network and I see you aretrying to find the code for your Coby TV. We currently do not have thatspecific code but we do have what we call a SAT Auto-Tune and it finds thethree digit code for your TV, I will send the link with the steps to help withthe setup; http://www.dishnetwork.com/SupportSection/sat-autotune
Hi, I own a coby
bought a coby tftv 2425, had a uverse remote that was set to my old zenith, it shut the tv off! The code is1357. It worked on both the sets I bought. Bettter to be lucky than talented!
Where can i get the battery 7100 coby TF in fresno and do they have one ?
Have you already removed the battery? There will be information on it telling you which battery to use as a replacement. As a general rule I would suggest you Don't start taking things apart if you are not sure what you are doing! You could cause more problems than you're trying to fix. Ask at your local TV repair shops and even some of the computer repairers. They may be able to help you. You would have to ask them directly if they have one in stock but commonly if it isn't a commonly used battery they will have to order one in for you.
If you have the battery details you might be able to get one online.
HOW DO I PROGRAM MY COBY UNIVERSAL REMOTE CRC-02
If you don't have the code for your device, you can use the auto search method to find the correct code. Here are the steps:
Turn on the device you want to program.
Press and hold the Setup button on your remote until the LED light turns on.
Press the device button (TV, DVD, CBL, etc.) for the device you want to program.
Press the CH+ or CH- button repeatedly until the device turns off.
Press the Power button to turn the device back on. If it turns on, the remote is programmed successfully.
Otherwise, you need to search for the manual for the remote.
