HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
Posted on Mar 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My printer is all wireless with a lap top..Everything says thats the printer is conected to a network..But when you print a document and the box comes up telling you what is printing the top says offline?! Thats where it tells you what printer is being used then it says offline..When I go to printers it says it is online and connected?! What do I do? All prints are in que or pending
Level 3:
  • HP Master 7,733 Answers
  • Posted on Mar 04, 2011
HP Master
Level 3:
Answers
7733
Questions
0
Helped
1865110
Points
21487
Wireless Printing Center.
If you need more help post back!
Thumbs and testimonial are welcome!
I have three lap tops using network router. When I try to scan it only gives my sons lap top as its destination. How do I add me and my wifes to the option window?
Your quest is confusing.You need to install the printer in all your laptops in order to do a print job.If you want to scan a job from each laps all need to be with the printer wireless configuration.
2helpful
I got a new toshiba lap top and installed my printer to the lap top. the printer connects to my lap top and everything. But when I try to print...it does not print and says zero documents pending. HELP...
Right click on printer and take its properties, and click on advance tab. from there you will see options. spool print documents, kindly select print directly to printer.
Enjoy
Wireless printing to HP officejet Pro 8500 Wireless Printer
Open "Control Panel".
Open "Printers".
Click to select the printer.
Click the "offline/online" button, to mark it as "online".
Print.
When i unplug lap top lose enternet conection
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
I can't get my print server LPV2-USB-TX1 to work with my lap top. The print server is conected to my wireless router. Do I need to intall driver on my laptop? My operting system is windows vita
Are you able to print from any other computer in the network ?
If you are able to print from any other computer that means your print server is set up properly.
On your laptop you will need to add port for the printer.
make sure that the printer drivers are installed.
Click Here for More info
2answers
I just brought home a Lexmark X6650 and a brand new gateway laptop with windows vista. I get an error everythime I try to install the lexmark printer and it will not install correctly or print anything. It...
when you look at the icon of the printer does it have a check mark on it or in the upper right hand corner of the icon? you can also make sure its the default printer by right clicking the icon and selecting "default printer" then try doing another print test.
My printer on my mfc-210c want print any document from my computer,the ink is fine,it even print out the help list,but want print from my lap top
Hi-
Did you install the driver in your laptop? is it connected via USB or wireless? check printers and faxes under control panel and try canceling the documents in your printers queue if theres any, right click and cancel document and try reprinting.
Hope this helps
2answers
Printer to lap top hook up wireless
The main problem here is that the printer is not a wireless printer.
But you can install the printer wirelessly through a wirelss printing upgrade kit, refer the link bellow:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00867651&dlc=en&product=90809
Good Luck
2helpful
3answers
Network printer not printing properly
Hi Silly,
Try going to the Add/Remove programs and remove the drivers for your printer, then reboot, reinstall then, connect to the network printer, and try again,
Good luck.
k24674
Grand Canyon Tech
Grand Canyon Tech
