According to the Users Guide, the D-Link DIR-615 does not support the 5Ghz channel.
Frequency Range
2.4GHz to 2.483GHz
You can download the official manual from D-Link:
ftp://ftp.dlink.com/Gateway/dir615/Manual/dir615_manual_100.zip
You can try changing the router's default broadcasting channel. To do this, sign in to your routers configuration page. This may help your connection speeds by removing some of the interference.
Please let me know if I can assist you further.
Regards,
KYTechnology
You need to beware that 5Ghz may not be supported by your PS3, as this is not a wireless standard.
Wireless Standards are a,b,g & n
You probably should either relocated the router so its not obstructed by brick walls or metal objects.
Otherwise you can try move the PS3.
While its max throughput is relatively low, the router offered very consistent and considerably high throughput speeds on both our mixed-mode and long-range throughput tests. Unfortunately, its range is possibly the shortest among Wireless-N routers. If range is not important to you and your network primarily consists of 5GHz-based clients, the WNDR330 is a good bet. Otherwise, for the same price, we'd recommend the 2.4GHz-only Linksys WRT310N; or you can pay $50 more for the true dual-band Linksys WRT610n.
Do you have a 5G card for your PS3? I believe the stock card is 2.4G and subject to the interference of many cordless phones.
