Amana NED7200TW Electric Dryer Logo
Posted on Mar 02, 2011
I do not have any heat, but the tumbler works. this is an electric dryer. i looked in the machine and it looks like it will not be easy to get at the element. i had and older dryer and the front came off very easily, but this one is a bugger. any help with steps to get at the element would be appriciated
Anonymous
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Mar 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
3834
Points
44
If you look at the back of the toob when the dryer is running you should be able to see if the elements are turning red.In order to do this you will have to defeat the door switch(be careful, don't stick any part of your body in the dryer).
You may want to check your vent,if they stop up the dryer elements will shut off on high temperature.
Dryer takes too long to dry
may be the solonoid. mine did that to where the tumbler worked fine, but heat was really weak..$40.part and fairly easy fix
Dryer does not heat up when drying. Tumbler works but no heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101././
2helpful
Clothes get hung between tumbler tub and front of dryer and are scorched, what parts do I need to fix this?
You probably need a new glide kit on front panel
Unplug it and pop the topa068344.jpg to get into the machine and take a look see. This is the most simple of all dryers to repair. It uses glides on front for the tub to ride on and it uses a hanger 3e1ec1c.jpgbearing in the rear for the drum to ride on. The plastic cup that the drum is cradled in wears down to metal to metal and can actually be cut in half causing the drum to drop down and lock up. This dryer is very easy to work on. MORE HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3helpful
Huebsch Electric Dryer won't dry
Look for a faulty high limit due to excessive lint buildup in the machine. That or either the element is bad. very simple machine to repair. Huebsh electric? Better look at old style speed queen dryers for comparison. better yet Click THIS
Jul 08, 2009 • Dryers
5helpful
Tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
2helpful
Scraping noise with burning smell
You quite possibly have something like a penny or a paper clip stuck at the heat duct. ***First-shut off the electric to the dryer***. From behind the dryer, remove the heat tunnel and clean it out. You will be surprised how much lint gets past the filter. It's an easy repair, just a few screws. While you're back there, look around for any buildup in other areas.
Maytag electric dryer. Tumbler won't turn.
The first thing to check is the drive belt. you will need to turn the dryer on its side and look to see if the drive belt is broken. If this is o.k it will be the motor.
Dec 08, 2008 • Dryers
GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
1helpful
DRUM/TUMBLER ISSUE
look at the rollers of the drum, it could have been dameged already and needs to be replaced.
3answers
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
Top Amana Dryers Experts
Kolbrun...
Virgil Watts
Are you an Amana Dryer Expert? Answer questions, earn points and help others
