Tip & How-To about Dryers
Gas Dryer not Working Gas Dryer Not Heating
If your gas dryer is not working because it is not heating then you need to check this out. Today’s gas dryers often do not use the simple thermocouple with a pilot to prove the flame anymore. They use a much more complicated method of lighting the burner and proving the flame.
The use of electric igniters has become the standard for many dryers today. The thermostat calls for heat, power is supplied to the igniter, then after a certain amperage draw on the igniter, the gas valve is energizes to open and allow gas to flow starting the flame. As long as the amperage draw on the igniter is high enough then the gas valve stays open till the thermostat is satisfied.
Sometimes the igniter will crack and no current will go through and the igniter will not even heat up or glow. Sometimes the igniter will wear to the point where it will still heat up and glow, but the current draw will not be high enough to allow the gas valve to open. This creates a confusing situation where you look into the dryer and see the glow from the igniter, but get no heat because the burner never lights up. If this is the case then you will need to replace the igniter even though it seems to be okay. The only way to know for sure is to know what the current draw requirements are for that gas valve and to have an amp meter to check the current draw.
Most of the time the problem will be in the igniter, and not the gas valve. Gas valves can go bad, but that is the case in only a very small amount of the situations. It is a pretty safe bet that if you have a problem with you gas dryer lighting that you have a problem with your igniter.
http://www.fixya.com/support/r4312805-dryer_maintenance
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Dryers Logo
Hello! Yesterday we cleaned out our home dryer vents. Today the heat wil not come on in our kenmore elite dryer. It tumbles and blows cool air, just no heat. Suggestions? Thank you!
If you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice
Jul 25, 2011 | Kenmore Elite HE4 Electric Dryer
dryer wont heat up today
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 27, 2011 | Dryers
dryer worked great yesterday , today no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 06, 2011 | Crosley CDE6000 Electric Dryer
No heat
This information is Courtesy of expert heatman101
If your gas dryer is not working because it is not heating then you need to check this out. Today?s gas dryers often do not use the simple thermocouple with a pilot to prove the flame anymore. They use a much more complicated method of lighting the burner and proving the flame.
Nov 16, 2010 | Maytag Neptune MDG5500AW Gas Dryer
got today! lp gas converted but does not heat gas not ignited or even tying to kick on, runs like normal just no igntion. Help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Kenmore 95087 Gas Dryer
54,443 people viewed this tip
Top Dryers Experts
