Sounds like your drain is blocked. You may have access to it through the front at the bottom but If you cant access it from the front You will have to tilt the machine back as far as safely possible to access the bottom of the machine. Locate the drain pump which will be at the bottom font or back corner and remove the hose that connects the pump to the tub, you will need to have a basin ready to catch any water. You most likely have a sock or something stuck. Hope this helps
If
your washing machine will not fill, only hot or cold will fill or is
slow to fill then read these tips. I have covered many of the things
that can happen in these tips...
Washing
Machine Problems No Water
Washing
Machine Fix Washing Machine No Water
heatman101
Have you cleaned the filter normally located at the bottom front of the machine?
