Dishwashers Logo
Posted on Feb 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I turn the dishwaser on and assoon as it begins to was water comes out from the bottom of the door. What could cause this?
vpitman1
Level 2:
Scholar:
New Friend:
  • Expert 59 Answers
  • Posted on Feb 28, 2011
vpitman1
Expert
Level 2:
Scholar:
New Friend:
Answers
59
Questions
0
Helped
15796
Points
126
It sounds like a bad gasket or seal around the door. These are usually inexpensive and fairly easy to install, but I wouldn't run the dishwasher until you've had a chance to fix it. When you buy the gasket/seal, ask if you need a special type of adhesive to install it. You didn't mention the model, so I can't tell if you will or not.
2answers
No water entering the dishwashet
Check electic water inlet valve screen on lower left bottom of dishwaser, follow the inlet water line to locate the valve, turn off power, and water, reremove inlet water hose, and valve hose, check inlet screen for sand, wash as needed. re-assemble in reverse order,
Oct 13, 2012 • Dishwashers
Dishwaser problems
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Cycle begins and we can hear water filling up, but the arm doesn't spin, and water isn't being "sprayed" around the washer. We can hear the dishwasher "clicking" throughout the cycle, but nothing else is...
There are a couple of things here. One is the pump is not coming on. The other is the unit leaking. Check the door seal for rips or tears on the bottom. Replace as needed. Also check the sump in the bottom of the unit to see if it has a lot of debris in it. This can cause the pump to not start. It could be more complex like the water valve is not shutting down all the way. The control board is bad etc.
After a wash cycle my unit leaves a film on my glass'
first thing you need to do is purchase a bottle of dishwaser cleaner from your groc store in the diswasher detergent section red the instructions on the label add it to the cutlery tray in an empty dishwasher upside down remove the paper seal off the top of the lid do not remove the wax seal place the bottle upside down in your dishwasher turn on hot water tap and run till it is hot next turn on your washer set it to wasn and let it run a full cycle. when washer finishes open it up when it cools and fill rinse dispenser in door with a good quality rinse agent like jet dry close dispenser and when dishwaser is full of dirty dishes turn it on the jet dry will make your galsses come out crystal clear w no film and the dishwaher cleaner will help all your dishes come cleaner.Use the dishwasher cleaner aroun 4-6 wekks it cleans all the inside of the dishwasher and removes a lot of **** aND RESIDUE THAT ACCUMULATES IN DISHWASHERS OVER TIME
Dec 17, 2009 • Dishwashers
Water not draining in the bottom of the dishwaser,no power at all
if you have a row of buttons on the left side for heat cycles check them a shorted switch will cause a loss of current situation so that the drain solnoid wont activate
1helpful
I have a whirlpool refrigerator and it seem to be leaking from
The bottom front of the refrigerator or freezer door Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
The back of the refrigerator Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
  • If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
The inside ceiling of the refrigerator Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
The inside back wall of the refrigerator In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Underneath the front of the refrigerator If the refrigerator is equipped with a water dispenser on the freezer door, check if the water line to the dispenser is leaking. Also, check the drip pan to be sure it isn’t out of place, broken or cracked.
2answers
Dishwaser is stuck in Rinse/Dry cycle
It could be a sensor or timer solenoid in the dishwasher maybe broken and needs replacing.
http://www.repairclinic.com/bosch-dishwasher-parts-gg.htm
2helpful
No water coming into dishwaser.
  1. Valve shut off to dishwasher
  2. Float stuck (bottom right front corner inside - check for obstructions)
  3. Kinked water supply line
Greg
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
