Porcher 35020 London 30" Single Bowl Farm Sink, White Logo
Posted on Feb 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What strainer/disposal basket do I need to buy for Porcher Farm Sink? Sink did not come with strainer/disposer trim.
Anonymous
Level 3:
Genius:
  • Master 1,015 Answers
  • Posted on Feb 26, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1015
Questions
0
Helped
319895
Points
3041
I believe this uses a standard 3 1/2 inch diameter basket strainer.That is also the right size for the disposal. Thank you
Is there a way to bypass the disposal to be able to use the sink w/o the water dripping from the bottom of the Badger 5 disposal?
If disposal is leaking, it has to be removed before it damages cabinet and causes mildew.
Then install a different strainer basket if you want to connect tubular drain.
Tubular sink basket
http://media.rd.com/rd/images/rdc/family-handyman/2001/11/Kitchen-Sink-Basket-Strainer-af.jpg
Disposal sink basket:
http://0.tqn.com/d/homerepair/1/0/m/0/-/-/sink_flange_noted.jpg
You can also buy same brand and size disposal and install without changing sink basket.
I wrote ez disposal replacement steps that show disposal removal and tips for connecting tubular drain.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
What is the difference between standard strainer and strainer for food erator? I bought a replacement sink wiht standard strainer, which does not seems to fit garbage disposal
If you need new sink strainer basket for disposal side of sink, you have to buy new disposal.
Each garbage disposal comes with its own strainer basket so that disposal can connect and seal.
First, the disposal strainer basket is installed, and then disposal lifts up and attaches from below.
A rubber gasket comes with new disposal.
Rubber gasket fits between disposal and strainer basket so that disposal seals correctly.
Photo below shows how disposal connects to strainer basket using steel connector ring under the sink.
I wrote tips for installing a disposal from days when I worked apartment maintenance.
My garbage does not work.it makes humming sound for few seconds but does not rotate blades.
Use a broomstick handle to see if disposal blades rotate freely
If blades are stuck, use broomstick to wedge blades free.
If blades rotate freely, and motor does not turn on, then garbage disposal is broken.
Disposal mechanism cannot be disassembled for repairs.
Disposal will need to be replaced at some point.
I wrote tips for replacing disposal from days when I worked apartment maintenance.
Here are basic disposal parts:
1) Sink basket that connects to sink and is held with 3 screws from below.
2) Disposal body which connects to sink basket using metal ring.
3) Rubber washer between disposal and sink basket.
4) Dishwasher connection at upper part of disposal with a hose.
5) Electric wire from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connection on side of disposal
In apartment maintenance, we replaced disposal with same size and brand disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Using hammer and screwdriver, rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, black wire to black and white to white, and push in red reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Lift new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, Use new washer.
Connector ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
Image shows direction for connecting new disposal.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove 3 screws that hold sink basket, remove basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Always slap a good amount all around washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
The disposal will not work untill i take the wrench and turn it a few times then it works fine but the next day i have to do the same thing and it works.Can i lubricate it.???
Garbage disposal mechanism cannot be disassembled for repairs.
My badger 5 is leaking from the bottom around what seems to be the electrical cord opening. any suggestions
Your disposal is rusted out and needs replacement.
4) Dishwasher connects to upper part of disposal with a hose.
5) Electric wire coming from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connects to side of disposal
You might be able to buy time filling hole with epoxy or silicone caulk and let dry for 2 days.
10-year old garbage disposal had a good run.
When I worked apartment maintenance, we replaced disposal with same size and brand disposal.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal, or any do-it-yourself project.
My Garbage disposal works and it turns but it sounds as if something is loose in there...it's the Insinkerator 5-81.....Is it possible the cutting blades are loose and if so, how do I fix this?
Garbage disposals can get noisy and sound like they're eating spoons instead of banana peel.
You can put vacuum hose in sink opening and see if something is in there.
As long as disposal is not shaking around a lot, and causing pipes to leak, then you can use it until it dies.
Here are basic parts:
2) Disposal which connects to sink basket with metal ring.
3) There is a washer between disposal and sink basket.
4) The dishwasher connects to disposal with a hose.
I wrote tips for replacing disposals that you can use when disposal gives out.
When I worked apartment maintenance, we replaced disposal with same brand and size disposal.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Attach electric wire to new disposal, and push in reset button.
Attachment ring catches at three points, all three have to connect.
Remove old sink basket and clean sink opening.
For a price, fixya expert speaks with you over phone while you work on disposal.
How do you disassemble the Badger5 1/2 horsepower sink erator.model #5-81
The badger has two parts:
1) The sink strainer basket that attaches to sink with three screws visible from below.
2) The disposal which connects to sink basket with connector ring.
If you drop disposal loose from the sink, you can get spoons and other stuff out.
The disposal itself does not come apart for repairs.
I wrote tips for replacing disposal, which include information you might be able to use:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
Push new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, use new washer.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
2answers
One of the grinder broke inside the unit, is this a replaceable part?
If disposal has loose parts inside, you have to replace the disposal.
If disposal still work and doesn't vibrate and loosen pipes under sink, then it's ok.
The don't sell replacement parts for disposals.
I wrote tips for replacing disposals:
Attach electric wire to new disposal.
Use new connector washer.
Leaking from the bottom of the disposal in the connection area.
Disposals rust out and need replacement.
Check a couple things first.
Run paper towel around top of disposal to see if moisture is leaking from around sink basket or dishwasher hose connection. Then check where tailpiece connects on side of disposal.
If these places are dry, the disposal has probably rusted out.
I wrote instructions for disposal replacement:
That way we didn't have to change out sink basket or change pipes.
How to change disposal: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Remove old sink basket and clean opening.
On image below loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Apply good amount on washer just before pushing washer in place and attaching nut.
Apply rectorseal where lower p-trap comes together.
Add a comment
Leaking from the bottom after removing something that got stuck in the spinning peace
Check a couple things.
Use paper towel and see if top of disposal is damp or wet. The basket strainer might have come loose and water is leaking down.
Fill sink and then release water all at once and check strainer basket and dishwasher hose.
Check where tubular pipe connects to side of disposal. Sometimes this joint can leak, and then water appears at bottom of disposal.
If top of disposal is dry and tubular pipe is not leaking, then disposal is suspect.
Disposals rust out, and dislodging something from cutter plate can open final crack.
If basket strainer is leaking, and disposal is older than 5-8 years, you might consider new disposal since disposal has to be completely removed to reseal basket strainer. See link below for basket strainer steps.
If it comes to this, I wrote tips for installing new disposal
http://www.fixya.com/support/t6995519-badger_1_2_hp_in_sink
Top Porcher Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Porcher Plumbing Expert? Answer questions, earn points and help others
