Cars & Trucks Logo
Posted on Feb 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i have an 1986 toyota 4runner the dash lights and running lights stopped working... fuse is blown and checked wires in the tail lights, marker lights and behind the dash with no luck... is there a switch that might be blown that controls the running lights
Anonymous
Level 3:
  • Master 395 Answers
  • Posted on Feb 26, 2011
Anonymous
Master
Level 3:
Answers
395
Questions
0
Helped
160056
Points
1163
The tail and marker lights and Instrument lights are on the same circuit so both will go out if the fuse for this circuit blows. If fuse continues to fail, check the tail light or marker globes, including the globes for the number plate, for a globe that may have an internal short causing the fault and replace as necessary. As you have already checked the wiring near the light fittings for any chafed wires that could be shorting to the body causing the fault, then a closer inspection of the wires inside all the light assemblies for any shorts may be needed.
It could also be that the instrument dimmer control has failed and is causing the fault. The electronic bits inside the dimmer control for these lights sometimes go faulty. Try disconnecting the connecting plug on the rear of the dimmer control and checking if fuse still blows. If fuse continues to fail, then the fault in the tail and marker lights circuit.
Remove all the tail, number plate and running light globes from the light assemblies and leave the instrument dimmer control disconnected and check if fuse still blows.
Disconnect the plug near each of the light assemblies to see if any of the individual assemblies is causing the fault. With all light assemblies disconnected and fuse continues to fail, then the fault must be in the main wiring loom some where.
If you have a Multimeter, it could be used to determine which light assembly has a fault between the lamp supply and earth connection.
1helpful
I need to find the fuse box in a 2001 toyota estima to access the fuse for the brake lights
Tail light fuse is located in the fuse panel behind a cover on the lower left of the dash. But note that this fuse controls parking, marker and tail lights. If the is blown, all these lights are out.
Have you tried new bulbs (it's possible both are burnt out?) Have you looked in the trunk for broken wires (especially the common ground.)
Why dont my dash lights work?
you can go to Toyota 4runner dot com and download wiring diagrams check your dimmer switch for the dash lights or possibly a fuse has blown I have had a car or two blow dash bulbs but that's very rare
2002 4runner no tail, running or dashboard lights
Check for loose connections. Jiggle the wiring at various places, for example under the dash, floor, side wall, engine compartment, engine bay fuse box and around the battery with key on engine off condition.
2answers
I have a 1987 toyota 4runner and no running lights or dash lights . The tail light fuse is ok but still no dash lights or running tail lights break lights light up fine.
THE DASH LIGHTS ARE USUALLY CONTROLLED BY A SMALL THUMB WHEEL NEAR THE HEADLIGHT SWITCH ON THE DASH. THAT IS A RHEOSTAT, THAT MAKES THE DASH LIGHTS BRIGHT & DIM. REPLACE OR BYPASS IT.
2answers
Dash and tail lights stopped working on my daughters 1991 toyota celica gt. the fuse has been checked and replaced. it was ok. the headlights were recently changed. is it true the dash and tail lights run...
If the tail lights and the dash lights stopped working and the tail light and the panel lighting fuses are both o.k. and you can find no other blown fuses then the problem is most likely the headlight switch.
3helpful
4answers
No dash lights when your lites are on out of a 1997 toyota hilux 4wd deisel .no fuses are blownen?
i have a 1992 hilux surf import turbo diesel and my head lights go on but no dash lights indicators work fuses keep blowing what does this mean??
Wiring problem
try to check all your fuses under the driver kick and under your hood beside your engine.
6helpful
4answers
Dashlights and temperature dash lights not working
Turn on your headlights and check to see if your taillights are working. They act as a fuse to your dashlights, its a safety thing
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
