Unless your friend opened up the drive, there's nothing he could have done to mess up the heads.
No you can't replace the heads, and if the heads are messed up, you MUST send this drive to a data recovery house such as MemoFix in Canada or DriveSavers in the US.
Be forewarned though that it will cost anywhere from 900-1500 dollars to get your data back.
If you were in the middle of writing a best seller, or have your entire company finances for the last 7 years on it, it might be worth it. Otherwise, I'd bid farewell to the data.
Testimonial: "I'd guess i too should bid farewell. There was no data that was worth the money i'd spend on recovery. anyway a costly lesson leant.. Thanks for reply"
Hi.
If the hard disk been opened unfortunately you lost your data. You can try to send it to a data recovery company but it will cost few thousand bucks to get your data out of the disk plates.
Opening a hard drive to check it out is 99.99% chances of fail because of dust. If you can fix what was wrong and put everything back together and plug it the head will hit the dust at 7200 RPM and it's like a plane crashing on a mountain.
Good luck anyways.
Vince
Testimonial: "Thanks a lot. I expected this reply.. I only Had a teeny weeny bit of hope.. LOL any way have a nice day!"
