Hi jnm_merchant, Welcome to FixYa! How are you doing? If you don't have the drivers disc of the webcam, you can download the driver from the webcam manufacturer's website. If your webcam is A4tech PK-635, you can download it here: http://www.a4tech.com/download%20driver.asp
Instruction on How to download and install the driver properly :1 ) Press Download button to download the desired driver . 2 ) Save it somewhere where you will remember after download . We recommend that you save it on your desktop , so it will be easy to find . 3 ) After successfully downloading the driver , do not open the driver file until you make sure the following has completed : ***REMOVE / UNINSTALL any original mouse driver from the PC . ( If you forgot to do this part , your driver may not be able to install correctly and successfully later ) 4 ) After the original mouse driver has been removed , open the downloaded file . 5 ) Follow the on-screen instructions . 6 ) When it's successfully installed , please restart your computer . 7 ) After you have restarted the computer , plug the webcam into your computer and it will automatically recognize the new hardware. Hope that helps. Thank you for using FixYa.
Install online is unusual way to do. People usually will download the driver first via internet (online). After installer driver software have been downloaded, we can run the file for installation. If the installation success,we can connect printer to PC via cable data and we can start to use your printer. You can download the driver from here : Download Driver Canon Pixma iP2770
You should be able to download the correct driver for your QuickCam at http://www.logitech.com/en-us/support-downloads/downloads/webcams
Choose the model number, click on the support tab, select your OS and download and install.
Please rate this solution. Thanks.
Audio Driver for dv2000:
The audio installation involves two steps. First you need to install
Microsoft Universal Audio Architecture (UAA) Bus Driver for High
Definition Audio and then instal Conexant High Definition Audio Driver.
Both can be downloaded from the following links:
Please make sure that you install the drivers in the same order as it's mentioned in the post to avoid any problems.
Windows XP Device Drivers for dv2000(for AMD Processors):
nVidia nForce Chipset Driver: Install the nVidia Chipset Device software from the following link: nVidia Chipset Device Software
