Your drain for the inside unit is stopped up and the water condensate that drips off of the coils when the AC is running has no where to go, so it drips off of the collection channel and over flows to the bottom of the air handler, gravity dictates the place where it leaks. You are going to have to unstop the drain.
Component
Blower Motor Below right side oft?
Blower Motor Relay . In engine compartment fuse relay box
Blower Motor Resistors Below right side oft?
Blower Switch Below center oft?
Engine Compartment Fuse Relay Box Left side of engine
compartment
ignition Switch Below left side oft?
Cl90 (68-LT gry) Left side of engine compartment (fuse relay
box)
C20l (20-W HT) Below left side oft'?
C225 (13-Will) Below right side oft'?
Q216(8-WHT) Below right side ofi?
0203 Below left side oft'?
Blower Removal
1. Discharge the refrigerant from AC system. (Refer to the
operating instructions of
your refrigerant recovery recycling charging station for
proper procedures.)
2. Disconnect the inlet and outlet pipe from the evaporator.
NOTICE
- When connecting and disconnecting, refer to Quick Coupling
below
- Immediately plug all open fittings to keep moisture out of
system.
3. Remove the cover and drain hose.
4. Remove the glove box and disconnect the wiring harness
connector.
5. Remove the blower unit.
6. Install in the reverse order of removal.
7. Evacuate the refrigerant system. (Refer to the operating
instructions of your
refrigerant recovered cycling charging station for proper
procedures.)
S. Charge the AC system. (Refer to the operating
instructions of your refrigerant
Recovery recycling charging station for proper procedures.)
