not sure what memory stick you refer too but lets talk as if it was a micro sd card as i had the same problem for my ndsi XL what i did was to save all the information to my computer from my sd card i then did a google search and found a sd card formatting tool (http://panasonic.jp/support/global/cs/sd/download/index.html) i did the format put all the information back on the card and all is well again i hope this helps ?
IF power light comes on and a few seconds later goes off, do the self check this model has.
On front of set when this happens, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Watch the power light closely, it should blink a two digit error code like; 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
It usually means that you are using an SDHC card in a camera that only understands SD cards. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
If that isn't the problem, it may mean that your card needs formatting or has become corrupted, which will be fixed by formatting it. Formatting deletes everything on the card.
If that isn't the problem, then there may be a fault with the card or camera.
What year is your car and what engine? That makes a lot of difference. What the pulses should indicate is a code 12 is stored (code 55 is usually an "all clear" code, meaning that the ECU is done reading out the codes that are stored). If you got only a 55, it would mean you have no codes. 1255 means that 12 is the only code you have stored.
