Taylor 5599 440 Pound Tempered Glass Body Fat-Body Water Scale Logo
A
Anonymous Posted on Jan 27, 2011
I just need an owners manual for the Taylor 5599
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Jan 27, 2011
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3073209
Points
27242
The only way to get the manual is to contact Taylor on the link below.
http://www.taylorusa.com/taylor-support
1helpful
2answers
Where do I get a manual ?
you can purchase a manual of Taylor 5599 440 Pound Tempered Glass Body Fat-Body Water Scale on ebay or in amazon...http://www0.dealtime.com/taylor-glass-body-fat-scale-manual/products
3helpful
How do I get A manual for model 5599 scale?
Taylor customer service would be able to send you a copy of the manual either by mail or email. Here is their number. 1-866-834-3905. Here is their website. http://www.taylorusa.com/taylor-support
I hope that helps :)
4helpful
How do i program the taylor body fat scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
3helpful
How do I change the scale to read pounds instead of kilograms?
Turn over the scale, on the bottom, there should be a little black switch that you can use to select between lbs and kilograms.
1helpful
Need manual to reset scale to weigh properly
Either do a search for that particular scale brand & model, which should take you to the company, whom should have a manual on-line or go back under search and type in "users manuals". There should be several manual websites that come up. Just don't click on the websites that require money for their manuals, when you can get them for free at other sites.
Top Taylor Health & Beauty Experts
ZJ Limited
ZJ Limited
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
