Question about Taylor 5599 440 Pound Tempered Glass Body Fat-Body Water Scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Posted on Jan 21, 2010
Testimonial: "The website does not have a manual. Using 'search' or site map produces nothing. Another problem: scale reads only in cm and kg. Won't cycle to ft/lb."
Send them an email to [email protected] and see if they can help you.
Sep 28, 2016 | Taylor Health & Beauty
Aug 01, 2014 | Taylor Health & Beauty
Feb 10, 2013 | Taylor 5568 Fat Scale Stainless Steel ()
Apr 27, 2011 | Taylor 5599 440 Pound Tempered Glass Body...
Jan 27, 2011 | Taylor 5599 440 Pound Tempered Glass Body...
Nov 01, 2010 | Taylor 5568 Fat Scale Stainless Steel ()
Jul 08, 2010 | Taylor 5568 Fat Scale Stainless Steel ()
May 14, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
May 14, 2010 | Taylor 5757 Digital Glass Body Fat Scale
1,779 people viewed this question
