Question about Taylor 5599 440 Pound Tempered Glass Body Fat-Body Water Scale
How do I change the scale to read pounds instead of kilograms?
Posted by tzarina8 on
  • Anonymous Mar 23, 2014
    and I can't fix it
Anonymous
Turn over the scale, on the bottom, there should be a little black switch that you can use to select between lbs and kilograms.
Posted on Jan 03, 2010
My digiweigh scale reads 0 - LD what's that mean
Hi Douglas 0-LD means your digiweigh scales are in pounds, 0 means no weight and LD means pounds..... The link below shows how to convert LD to KGS (pounds to kilos)
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Mar 26, 2016 | DigiWeigh Measuring Tools & Sensors
Cannot get it to simply read weight in pounds
Hi dave,
Here is the Simple example of converting weight to pounds.
1 Kilogram (Kg) = 2.20462 Pounds (Lbs)
1 Pound = 0.453592 Kilograms
See the following links for Online Conversion Calculators:
http://www.metric-conversions.org/weight/kilograms-to-pounds.htm
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Hope it helps.
Thank you for using fixya.
Sep 09, 2011 | Health & Beauty
Instead of showing my weight in pounds (168.00), the window is showing a different kind of number (75.). I don't know how that happened. What should I do to correct this.
Your scale is showing you your weight in kilograms what you need to do is change the settings so it shows you your weight in pounds or stones
Sep 19, 2010 | Conair Weight Scale "Thinner" with Body...
I can't get the scales to read in pounds
Turn the scale over and there is a sliding button that allows you to choose pounds of kilograms. Joe
please rate my answer as very helpful. Joe
Mar 30, 2010 | Omron HBF-400 Fat Loss Monitor with Scale
Changed batteries and now the scale does not read correct weights. off by more than 40 lbs
You might wanna double check that your scale is set to the right measurement. On the bottom of the scale is a switch that allows you to choose between Kg (kilograms) or LB (pounds).
Jan 18, 2010 | Conair WW60 Weightwatchers Scale
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Mar 15, 2009 | Health & Beauty
Metric instead of pounds
You didn't mention brand name or model number, so not sure about your specific case. However, on my scale, there is a switch or button near the battery compartment. It allows you to change the measurement between stones, pounds and kilograms.
Jan 01, 2009 | Health & Beauty
Measurement is in kilograms instead of pounds
check if there is a tiny whole in the back you could probably poke it with a needle
Jan 01, 2009 | Tanita Health & Beauty
Taylor 5599 440 Pound Tempered Glass Body Fat-Body Water Scale Logo
1,108 people viewed this question
Top Taylor Health & Beauty Experts
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
Marvin
Marvin
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
