Best Buy™ offers repair on televisions in different ways depending on the size.Smaller televisions are typically repaired on a carry-in basis, while larger sets are usually serviced by a technician that comes to your home.I suggest you call 1-888-Best Buy™ to determine which type of service applies to you.
? 6:43
https://www.youtube.com/watch?v=8HG7efTMj78
Jan 3, 2014 - Uploaded by ShopJimmy.com
LED TV Repair Review & Overview-Common Problems - Symptoms, Solutions Click Here to BUY TV REPAIR PARTS: ...TVs inputs and outputs, this main board is connected to thebacklight inverter/LED driver via this ribbon cable. ... ofillumination for the screen and the board that drives thatillumination.
? 2:30
https://www.youtube.com/watch?v=s3r1GZCA0K4
Dec 31, 2012 - Uploaded by ShopJimmy.com
Philips TV Repair Flickering Image On TV Screen Tutorial Guide How to ... Inverter on LCD TV Easy Fix Help Click Here to BUYTV REPAIR PARTS: h... ... How to Replace the Backlight Inverter Board in LG & Philips LCD TVs.Missing: restore illumination
? 1:38
https://www.youtube.com/watch?v=cWpF4q_rBaw
Oct 19, 2014 - Uploaded by EurekaRecycler
SEIKI Tv SC501TS has audio but no video, repair ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
Learn why your screen is blank and you have audio - No image LED TV Repair Review Main Board Problems ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
? 25:30
https://www.youtube.com/watch?v=zxqDLDNuCfw
Jul 8, 2013 - Uploaded by RetroGameModz
This is a documented repair of a Samsung LCD TV that I got for cheap. It was listed as not working, which is ...
? 8:23
https://www.youtube.com/watch?v=n54IurMvr6o
Apr 4, 2014 - Uploaded by ShopJimmy.com
Samsung LCD TV Repair - TV Won't Turn On - How to Replace ... or if you have standby and the TV will ...
The tv LCD screen panel itself it is dead,by force.Sorry,no not repairable.Only way to repair this tv,it is to replaced the whole LCD screen panel itself,not practical or possible because the LCD screen panel it is mission impossible to buy as a refurbish items,only can buy it from tvs manifacture itself only,but it 90% important to the tv and it functions and it is very limited production items,so they'll sell it to u,but the cost it is the same as a new tv.Buy a brand new tv it pretty cheap these day at Walmart stores.Tries buy another tv same make and model as ur old tv.Save the dead broken LCD screen panel old tv somewhere for later years,as refurbishes electronic PCB boards for ur new tv later uses.
That sounds like your back light has gone out. Either the back light or it's power supply failed. If you turn it on and get close a bit to the side you should see a ghost image. That will confirm it is a back light instead of a video section problem. A lcd type display creates the images on the lcd panel, but it doesn't generate any light. The backlight shines through and illuminates the images. Very much like a slide or move projector.
The repair cost really varies from model to model. The actual backlight can be repaired for under $150 in most cases. How ever if the power section is part of the main tv board then the entire main board needs to be replaced. That board on other sim sized tv's can run over $450. This is covered under warranty so the first thing you need to do is check if you have any warranty either extended store or the oem warranty. Then contact the store you purchased or go through the Phillips support to find your local repair depot and get ti sent in. If you do not have warranty then you have to be careful as you are paying for this. You need to get a estimate. A repair depot will have a very good idea of the repair cost.You should also have an idea of what a replacement tv is worth. Once you know how much the repair cost is you can then judge if it is worth fixing or if you should get a new tv. A new tv has a new warranty while your repaired tv will not. So if the repair gets too high you are better off replacing and not having any worries.
An internal component is most likely heat sensitive, shutting off, cooling of slightly, and then turning back on. The unit will have to be troubleshot. Call the store it was purchased from for options of repair. You can also contact Viewsonic suport here: http://www.viewsonic.com/support/customer-service/
Some loca TV repair shops have mobile services, where they will fix it at your place. Look in the Yellow Pages for TV Repair.
Good luck, and hope this helps.
Yes,but this LCD screen crystal pannel is exspensive,check the new LCD TV in the store first,see if worth repair the LCD Screen crystal pannel.Tries these websites.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com for the part.
