ASUS M4A78LTM LE Motherboard Logo
Posted on Jan 21, 2011
My internet speed has been reduced to 1mb from 3 mb since installing this motherboard. My router shows 3.5mb speed and my connection is 100mb duplex. Everything appears OK but the speed will not go above 1mb. Using my other computer brings the speed up to 3mb.
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Apr 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
6462
Points
13
Follow the following steps to increase the speed
1. Go to Start-> Run-> and type gpedit.msc
2. Expand the Administrative Templates branch
3. Expand the Network tab
4. Highlight QoS Packet Scheduler
5. Click on Limit Reservable Bandwidth and check the enabled box
6. Then Change the Bandwidth limit % to 0 %
After that check the speed here http://www.scanmyspeed.com/
Anonymous
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Jan 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
4562
Points
90
Use speedtest.com site to verify download is stuck at 1mb
then check the lan settings for the hardware
goto control panel system and check the properties on your lan device
10mb could do this.. maybe
2answers
Slow internet speed behind cisco router
Greatings !
I put WORKGROUP within the domain name field of the Network tab.
Speedtest moved from 10Mb to 100Mb that is the maximum speed provided by my cableBox (Numericable).
Very good
Thanks a lot to Kasper Mikkelsen
3helpful
2answers
While testing my connection speed from sppedtest.net I am noticing speeds of 20Mb wirelessly over my N-draft 270 Mbps D-link dir 635 router.I pay for a 30 Mb connection from UPC though.I plugged an...
As of me, there is nothing can be named , THE BEST , but i have been using http://www.ip-details.com/ for the past 3 months to check my system speed, it was accurate and user friendly to check the speed of our internet
1helpful
Software to restric internet access
You can use a Bandwidth limiting software on the appropriate laptop that can set an Upload and Download speed limit on any Internet accessing software: it is a fair-priced commercial s/w called 'Netlimiter' and you can download the 'PRO' version on a 28-Days evaluation from: http://www.netlimiter.com/download.php
Very handy to limit each application bandwidth especially Data transfer from your Laptop when using a browser (such as IE/Firefox/Chrome) at the same time as a Peer to Peer application (such as Azarus/Edonkey/EMule).
1helpful
Everything is connected but the receive light is flashing and the pc/activity light is orange.All other lights are off
On a on a surfboard modem would mean that you are only connecting at 10 Mb as opposed to 100 Mb
If you have a router it may well be a setting on the router.
otherwise I would look for a cable fault or network setting.
In theory it will not make too much difference if you only have a 5mb high speed connection.
In practise it may mean slightly slower pages on the INTERNET.
Start with checking you network settings for you wired connections more so in the properties for your Ethernet card.
If you can, look for a FULL DUPLEX setting and set that to auto.
I would also look at maybe replace the network cable and check that you are also plugged into the correct ports on any router.
eg. modem to router is the yellow Port or WAN
router to computers is usually black ports or LAN (usually 1 to 4)
3answers
What is the maximum speed
The speed of that router is 100 mbps (wired) and 54 mbps (wireless). If you have a 1 mbps line, that router is more than sufficient. Your speed will change simply because someone is using the internet connection. Downloading, uploading, surfing, chatting, listening to internet radio, etc. Make sure no one is on, then test it to see what speed you get. Go to www.speakeasy.net/speedtest and select the server nearest to you. It is a very good speed tester.
Good Luck!
Wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: 192.168.1.100 ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
WINS:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
How do I reduce the card speed of the Network Interface Card?
To Reduce the link speed of your adapter to 10 half duplex, click Start | Control Panel | System | Device Manager | Network Adapters -> your NIC card properties ->Advanced Tab -> Link Speed = 10mbps half duplex.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
