1998 Toyota Camry Logo
Posted on Jan 21, 2011
I have a 1998 Camry LE and I broke off the housing on the passanger side mirror, and yesterday I bought a new mirror, on the original mirror it wasnt heated, and the guy who i bought the new mirror said the heated one would connect with the original wiring yet I'm looking at it and there is no connector in the original wiring the only connections are inside the door panel and on the very end of the old mirror and it wont fit in the new one. Is there a wire I can buy that would fit in the new heated mirror or do I have to find a new mirror that isnt heated?
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Jan 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
2898
Points
51
Toyota only wrecking yard
Replacing driver side mirror assembly on a Toyota
undo plasic cover inside the door remove holding bolts and do the reverse to put new one on
8helpful
2answers
2007 Toyota Camry LE - broken sun visor
most likely a defect. call the dealer and see if toyota has issued a recall on the visor and you might have it replaced for free. other than that, there's always the junkyard.
1helpful
2answers
I broke my passanger side mirror. I bought new
REPLACEMENT GLASS IS AVAILABLE AT YOUR DEALER SHIP AS THIS CLASS IS A CURB GLASS AND NOT A FLAT GLASS AND FITS PERFECTLY.
2helpful
2answers
Broken driver side view mirror-2005 camry
Heated mirrors usually have a symbol on them -- a small diagram showing squigley heat lines.
If you don't see this, it's probably not heated. But when you take the mirror off, if it's heated it'll have wires connected to the back.
Yes, you can replace a heated mirror with non-heated -- just leave the wires tucked out of the way when you install the new mirror.
1helpful
Replace left side mirror assimbly 1998 camry
Just remove the plastic triangular cover that is on the door. There may be a speaker behind it that will also have to be removed. Once these are off just unplug the little white wiring harness and remove the three 10mm nuts that secure the mirror housing to the door.
when you are tightening up the new mirror be sure not to over tighten as you could break the new part.
Cheers
2002 Camry Driver Sideview Mirror
the mirror u bought is wrong for sure. some side view mirror are HEATED that's why the prong/plug is different.
1998 toyota camry lxe. car just mysteriously died while driving.
the solenoid would keep the starter from working at all. i would look elsewhere for the problem
2007 Dodge Grand Varavan - How to tell if side view mirroris heat
no you can buy either heated or non hated mirrors and be ok either way. once you put the new one in place you will need to make sure you hook the controls up so you can control it from the dash
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
