I have a Kenmore HE 3t front loading washer and i left a load of clothes overnight in it accidentaly and went to restart the washer and the display read F 32. i tried unpluging the washer and plugging it back into the outlet and that hasnt fixed the problem.
AnonymousAug 05, 2008
How do you fix the F 32 Code. It says pressure switch. What could go wrong? I've only had this unit for 3 months.
I have the same problem. I tried unplugging, hoping it would reset, but it wouldn't. The clothes are dry and the motor just keeps churning. What is the solution?I have the same problem. I tried unplugging, hoping it would reset, but it wouldn't. The clothes are dry and the motor just keeps churning. What is the solution?
I also have a code F32 error I had Sears come out and he said it wasnt the Pressure switch it was the Main control and wanted to charge me 700 to fix I said no way. My washer is only 1.5 years old Ive had 2 other people come out and look at it and one tried to replace the main computer board and it still errored out. So now I dont know what to do. One didnt even want to touch it, he thinks it both the PS and Cntrl board! HELP I also have a code F32 error I had Sears come out and he said it wasnt the Pressure switch it was the Main control and wanted to charge me 700 to fix I said no way. My washer is only 1.5 years old Ive had 2 other people come out and look at it and one tried to replace the main computer board and it still errored out. So now I dont know what to do. One didnt even want to touch it, he thinks it both the PS and Cntrl board! HELP
You can't post conmments that contain an email address.
F32 is a pressure switch failure. It controls the water level in the washer. The switch is a round plastic part mounted on the right panel towards the back right corner. Remove the switch by disconnecting the wire harness and the rubber tube connected to it and gently rotate it 90 degrees CCW and you should be able to pull it out easily. Some suggest that blowing on the tube will clean out anything that could be clogging it as a quick fix. If you suspect the switch you test it by checking two things; Blow on the inlet that was connected to the rubber tube you should hear a couple of clicks. The second test is to check if the switch works electrically. If the switch is bad you will need to replace it.
F/32 error code; this indicates a pressure switch failure. The Sud error code indicates a suds lock condition. Be sure that you are using HE laundry detergent & the drain hose is not too low.
I checked my code book and there is no f32. you should have a code tech sheet. this would be located on the bottom panel insid the washer. Check to see if they have a f 32 code.
Mine had F51 and F32. After reading the solution #1 I checked the drain pump for any clogging but it was a broken wire (blue) in the pump connector. It was (long but) an easy fix, because the connector is IDC and we just need to open the cap, take out the remaining wire piece, reposition the wire in the blade and close it again, using a pipe plier. It's back to life.
F32 is a long drain fault code. Tip your washing machine back far enough that you don't have to hold it up. At the back of the unit there are two "things" with hoses coming out of them attached to the bottom of the outer tub. On the left is the recirculation pump, and to the right is the drain pump. Take a wet/dry vac and get as much water out as possible through the end of the drain hose, then pull the hose off the drain pump, remove the pump, and look for coins/shoelaces/whatever might be blocking it on the inside.
What make and model is your washer? This applies to Whirlpool cabrios. Just reread your message and realized that I have no idea what you're talking about. F codes are pretty common in different brands, but "32" could mean anything. All depends on what you're looking at.
Got the same error here, called Fisher Paykel and the said it's an error related to the water line. They recommended running 3 L of water and see if code disappeared. If not, call service, they gave me a local company. Error code has disappeared, for now.
We found out that the F32 code means you have a faulty pressure switch. From my online research this is a common thing with the whirlpool.
We had just bought it and the next day when it was delivered we were excited to try it out and got that bloody F32 code...luckily 2 days later we got it fixed by a repairman.
I have know idea why Whirlpool would make a product with all sorts of codes, but no explanation as to what they mean. That makes no sense.
Hello, I seem to have the same problem!
