Many times when the inside light fails to operate...it could be:
(1) A bad bulb ...replace with a known good one.
(2)
Bad connection of the light bulb in its socket.
(Remove the bulb and spray the socket with WD-40 Spray Lubricant) then...
(3) Replace the bulb with a known good bulb..use a dry rag to
securely tighten the bulb in its socket.
(4) The "
Door Switch" could be bad. Replace bad "
Door Switch" with new one.
Hopes this helps....Good Luck! ......
HandyHenry
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/henry_239f63a136de60f0
how do i get at the lamp for sony wega KDF50WE655 so i can replace it
